Navigation & Audio HK Amp Access and driver side rear hinge cover
Old Apr 22, 2010 | 08:52 AM
tutono's Avatar
tutono
I am brand new to this forum so please bear with me. I have a need to bypass the HK amp in my 2006 Coop Sport Conv, but I need to knoe if I can access the HK amp with out much hassel or do I have to tear the rear interior out to do so. I know it is located some where in the right rear of the vehicle. I am also wondering if anyone can tell me the part number for the rear plastic boot hinge cover. it slips down over the hinge itsself and into the bumper.
Old Apr 24, 2010 | 02:29 PM
Eric_Rowland's Avatar
Eric_Rowland
Not sure about the convertible, but in the coupe you can access the one inaccessable screw through the hole where the boot light sits. Others have said you need to pull the interior panel.
Old Apr 25, 2010 | 05:20 PM
rkw's Avatar
rkw
In a 2006 convertible, the HK amp is under the passenger seat, which is attached with 4 bolts at the seat rails.
The driver side hinge cover is part# 51127151815.
http://www.realoem.com/bmw/showparts...13&hg=51&fg=15
Old Apr 26, 2010 | 05:10 AM
101dals's Avatar
101dals
Just make sure you disconnect the battery before you pull the seat out. If you don't, you will get an air bag fault light on the dash when you disconnect the seat.
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
bugeye1031
Aug 15, 2015 08:14 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
