R50/53 Best way to disable car from starting (for compression test)?
Old Apr 3, 2010 | 07:10 AM
plasticknives's Avatar
plasticknives
Would it simply be pulling the plug wires and the fuel pump relay?
Old Apr 3, 2010 | 07:20 AM
jhiggs26's Avatar
jhiggs26
You want all your spark plugs out so yes no leads attached. Also disconnect coil wire.
Jeremy
Old Apr 3, 2010 | 08:02 AM
plasticknives
Ended up unplugging the fuel pump relay and ran the car until it died. Then pulled all the wires, and one plug at a time. Cranked the motor for 10 seconds with the throttle open and came up with these results:
#1 175 #2 170 #3 180 #4 181
10% variation from 180 is 18 psi so I think I'm pretty good!
This test was done cold BTW.
Old Apr 3, 2010 | 11:29 AM
Fatherdeth's Avatar
Fatherdeth
Very good numbers. How many miles are on the car and is it an '02?
Old Apr 3, 2010 | 12:09 PM
plasticknives
02 MCS with 79200 on the block and an 05 head with 30k on it.
Old Apr 3, 2010 | 07:05 PM
K5Cruiser's Avatar
K5Cruiser
You're GTG!
TunedGP
Oct 1, 2015 04:18 PM
kpl
Aug 11, 2015 04:52 AM
Lt. Dan
Aug 10, 2015 12:46 PM
veevsato
Aug 5, 2015 04:42 AM
