R56 Wheel Spacers....?
Old Apr 2, 2010 | 09:20 PM
Hoopty's Avatar
Hoopty
I did some searching but couldn't find the answer.....
I have a 2008 MCS with Mach V springs, Web spoke wheels, and 215/45-17 RE-11 Bridgestones. Does any know what is the largest size spacers I could run without rubbings? Looks like maybe 10-15mm might work, but I want to be sure before ordering.
Thanks, Hoopty
Old Apr 3, 2010 | 01:49 AM
ChrisTKHarris's Avatar
ChrisTKHarris
Best way to tell is to measure the gap between the outside edge of a tire an the fender lip.
Old Apr 3, 2010 | 07:23 PM
kukaepe's Avatar
kukaepe
I'm running 16mm spacers on my '07 MCS without any problems so far. I agree with ChrisTKHarris regarding measuring the clearance on your car before ordering. Good luck.
Old Apr 3, 2010 | 07:31 PM
ChrisTKHarris
TurnerMotorsports.com sells H&R Trak spacers, they're hubcentric and come with extended bolts.
Old Apr 4, 2010 | 06:56 AM
slinger688's Avatar
slinger688
Generally spacers that are larger than 12 mm are hubcentric. The ones narrower than would not be.
It is better to get the hubcentric ones.
Old May 11, 2010 | 08:11 PM
BradM's Avatar
BradM
H&R 5mm Spacers
I am going to run with some H&R 5mm spacers on my R56 with 18" JCW R105 wheels. Do you think that using 14 x 1.25 bolts in a 35mm length will be long enough.
Old May 12, 2010 | 06:30 AM
Mach V Dan's Avatar
Mach V Dan
They don't need to be, since a thin spacer (5mm, for example) allows the centering snout from the hub to still poke through and center the wheel.
We stock a whole range of H&R spacers for the MINI, by the way. They include longer bolts, too. HERE.
--Dan
Mach V
thebordella
Aug 31, 2015 01:37 PM
trw92a
Aug 26, 2015 01:47 PM
Zettinger
Aug 25, 2015 04:04 PM
