Oil leak, need suggestions
Old Apr 1, 2010 | 08:19 PM
tiny s's Avatar
tiny s
I have been replacing parts from the ground up on a used 04 mini s that I bought. There was oil leaking from the valve cover and oil gasket so those parts where replaced too. Everything seemed good for a week or so until today. I found a puddle in the garage and checked it out. Its oil and its dripping from the passenger side of the bottom of the motor somewhere. Anyone have any ideas of where it could be coming from?
Old Apr 2, 2010 | 06:16 AM
thulchatt's Avatar
thulchatt
Just a guess but maybe the oil pan gasket. It is a know problem with 1st gen MINI's. Not an easy repair.
I had my first gasket replaced under warranty but now have a small leak again. For me I am waiting until it gets worse or I need other work done and watching the oil level.
Old Apr 2, 2010 | 06:38 AM
newbs49's Avatar
newbs49
+ 1 for the oil pan.
Also check frt crank seal.
Old Apr 2, 2010 | 07:20 AM
tiny s's Avatar
tiny s
stuff
I guess it could be the oil pan gasket again. I just replaced it 2 weeks ago. Does anyone use a silicone on the gasket as well or should it just be the gasket?
Old Apr 2, 2010 | 07:57 AM
ZippyNH's Avatar
ZippyNH
Since you already replaced oil pan gasket....it might be something else.
Why don't you clean the motor...drive a few miles...then look more closely. Might be the seal/gasket behind the crankshaft vibration damper...
I would do some more investagation....maybe pay some $$ to get it diagnosed before throwing more parts and time at it!
Good luck!!
Old Apr 2, 2010 | 08:16 AM
tiny s's Avatar
tiny s
Okay, that leads me to another question. About 4 days ago I noticed vibration from the engine when accelerating on the highway. It actually seemed to get a bit worse lately. Could this have something to do with the crankshaft vibration damper?
Old Apr 2, 2010 | 08:58 AM
ZippyNH's Avatar
ZippyNH
Unlikely...when it starts to slip/fail...the car is usually not moving for long...it can coast...but no sc, no waterpump, no sc, no alterntor, no ac.....
You still have the oem damper?
Thevundampened aftermarket ones do physically fail...they can crack/brake, and they can also cause faster wear of the seals on the crank, and the bearings....
The ATI ones (aftermarket)are lighter weight, dampened, and avalable in stock and oversized...very nice, and cheaper, and more relilable than oem. Waymotorworks has both...the stock sized ati, and the oversized!!
Old Apr 2, 2010 | 02:38 PM
tiny s's Avatar
tiny s
stuff
I got under the car and found that oil is dripping from right underneath the oil filter area. What might be there that would be leaking oil? I cant pin point the exact spot. Thanx again for the help.
Old Apr 2, 2010 | 02:59 PM
Eric_Rowland's Avatar
Eric_Rowland
Could be oozing from a slightly split o-ring. Might want to pull the canister, check/re-oil the o-ring and reinstall.
Old Apr 2, 2010 | 04:57 PM
R53-BRG's Avatar
R53-BRG
If it isn't the O-ring, it is most likely the oil filter housing. I had to replace mine as well. It's a $10 gasket and takes about 1hr to complete.
Old Apr 3, 2010 | 02:28 PM
tallweed's Avatar
tallweed
Hydraulic Motor Mount
Have you checked the hydraulic motor mount? It's filled with oil and when it fails, oil will leak down the passenger side of the engine. Mine split about 6 months ago and gave me a small heart attack when I saw the oil on the ground. That might account for the additional vibration you noticed. I was lucky and it didn't actually get on the engine or even worse, the belts on the front of the engine.
Old Apr 3, 2010 | 02:38 PM
tiny s's Avatar
tiny s
No, It cant be the mount, Im missing quite a bit of oil from the motor too.
Just curious, does the oil filter housing screw off?
Old Apr 3, 2010 | 04:54 PM
ZippyNH's Avatar
ZippyNH
The oil from the motor mount is kinda thick....it's kinda hard to mix it up with engine oil. The oil filled mounts are on 05+ mini's too I think...
I believe to always rule out the simple stuff first.
Was an oil change done recently? Even if not...it might be worthwhile to take the filter off, and put a new oem filter and O-ring in the filter housing... Then check for leaks. The o ring is easily damaged during install, and some aftermarket filters sometimes have an o-ring that is undersized, allowing a leak. Sometimes the oring can end up in the wrong spot too when installing the cover...cost to try this fix...maybe $8 for an oem filter.
An oilchange at the same time...harder to justify cause clean oil might be harder to spot a leak...but definetely top off the oil to full...
Old Apr 3, 2010 | 06:23 PM
tiny s's Avatar
tiny s
stuff
True. I actually pulled the filter which was in correct. I noticed that there are 2 hoses side by side directly underneath. Are these the coolant hoses going to the heater core? If not could these have something to do with the leak? The oil is coming right from the general area which again is directly beneath the oil filter. Sorry, Im waiting on a Haynes book coming in the mail.
Old Apr 3, 2010 | 06:43 PM
R53-BRG's Avatar
R53-BRG
The hoses are the in/out for coolant for your sandwich oil cooler. Past that is where the whole assembly mounts to the motor. This is most likely where your leak lies. If this does prove to be where the leak is, no worries, the gasket is under $10 from the dealer.
Old Apr 4, 2010 | 11:47 AM
MrCooperS's Avatar
MrCooperS
Moderator
It's probably your oil filter and gasket. A lot of gaskets from non-oem oil filters do not sit right and usually causes leaks.
Old Apr 4, 2010 | 07:15 PM
tiny s's Avatar
tiny s
stuff
Right on, found this online. Who needs a manual with the internet? Lol. I will pull this and replace the gaskets, Im 100% sure its within this component. Thanx to everyone for your help.
http://www.allminiparts.com/showAsse...sembly=c_d_157
Old Apr 4, 2010 | 07:37 PM
bigballer23's Avatar
bigballer23
I second the oil filter gasket. I just put a new filter in and had a leaking problem. I took it off and then tightened the **** out of it when i put it back on. No problem since.
Old Apr 4, 2010 | 07:57 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Over tightening the filter housing is not a good idea. The seal is entirely the O-ring so if it is leaking the O-ring was not seated correctly. Gorilla force on the housing will not stop a leak like a traditional spin-on filter.
Rich
Old Apr 4, 2010 | 08:03 PM
bigballer23
Mabey not the best idea going ape on the filter. Ignore what i said earlier. thanks rich.
woodstudio
Mar 15, 2020 08:28 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
