04 Cooper: annoying on/off throttle jerk
Old Apr 1, 2010 | 07:42 AM
ulrichd's Avatar
ulrichd
My "new " 04 Cooper with 53K miles has a tendency to do a little drivetrain jerk or lurch when I go slightly on and off the throttle at low speeds. To passengers it seems as if I am just learning to drive a stick. Very hard to modulate the throttle.
Before I spend hundreds of dollars replacing all the engine and tranny mounts I want to make sure it's not a drive by wire throttle/software issue. I don't remember my old 03 MCS doing this.
Any thoughts and comments will be appreciated.
Old Apr 1, 2010 | 07:47 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Do you have a Cooper now or a Cooper S ?
Old Apr 1, 2010 | 07:50 AM
ulrichd's Avatar
ulrichd
04 Non-S Cooper.
Old Apr 1, 2010 | 09:33 AM
JohnnyVillan's Avatar
JohnnyVillan
CVT?
Old Apr 1, 2010 | 09:38 AM
ulrichd's Avatar
ulrichd
No, 5-speed. It's been suggested that I take a look at the TSW upper engine mount. Any thoughts?
Old Apr 1, 2010 | 10:09 AM
markjenn's Avatar
markjenn
You may be feeling the idle fuel cutoff. On my S, it occurs at about 1500 rpm during off-throttle deceleration while in gear - a small but pronounced little "jerk" as the engine goes from supplying no decel fuel (to decrease emissions and increase fuel economy) to adding enough fuel so the engine won't stall.
I use the clutch more at low speeds than I would otherwise to smooth things out.
Engine mount problems are pretty easily diagnosed if the mechanic is experienced enough to know what to look for.
- Mark
Old Apr 1, 2010 | 11:56 AM
rkw's Avatar
rkw
The symptoms you described sound very much like slack in the engine mount, and the TSW mount should help. I have the TSW, and it makes the clutch engagement much nicer.
Another one to consider is the VIP stabilizer (http://www.vipcustomparts.com/minicooperparts.htm). I really like this design but it wasn't available yet when I got the TSW.
Peking Duck
Jan 19, 2021 03:17 AM
Qik420
Oct 4, 2015 08:19 PM
potterstein
Oct 2, 2015 09:30 AM
Oct 1, 2015 12:13 PM
Qik420
Oct 1, 2015 12:02 PM
