17s or 18s? Please HELP
Old Mar 29, 2010 | 05:10 AM
nickster's Avatar
nickster
Can anyone help me out? Need some expert advice. I'm currently choosing between 17 and 18 rims. I have an MC 2008 and running with stocks. We all know that 18s give a great look to our cars but does it compromise the ride and comfort? 17s as some say is pretty safe in terms of comfort since the tires can be thicker. In my area, there are quite a lot of bumps and uneven roads. And in case I choose 18s, will it somewhat change the ride height of the car as well? I'm not really a fan of too lowered cars. Hoping to get the same height as it is with stock. I just bought koni fsd shocks, would it help? How about the tire sizes, what would best fit 17 and 18 rims? Basically its looks vs comfort. Is it possible to have both?? Please guys need your know-how on this.
Last edited by nickster; Mar 29, 2010 at 05:13 AM. Reason: some typographical error
Old Mar 29, 2010 | 07:09 AM
Alex@tirerack's Avatar
Alex@tirerack
215/45/17's are the size I'd target!
Old Mar 29, 2010 | 07:13 AM
dortoh's Avatar
dortoh
I'm no expert but typically less sidewall will translate into a harsher ride but better handling. It will also increase the chance of wheel damage when encountering road hazards such as potholes.
I'm assuming your stock tires are 205/45/17 which has a sidewall of approximately 3.6" and a diameter of approximately 24.3". If you use an 18" wheel with a tire that has close to the same diameter(205/40/18) you will have a sidewall of approximately 3.2" and a diameter of approximately 24.5".
215/45/17 = sidewall of approximately 3.8" and a diameter of approximately 24.6" but slightly wider than a 205/45/17.
Also a different diameter tire will cause your speedometer to read incorrectly.
Hope this helps...
Old Mar 29, 2010 | 09:52 AM
veggivet's Avatar
veggivet
I run 215/45/17's along with Koni FSD's and am very happy with the ride quality. If you have a lot of potholes, you probably will be happier with 17's as opposed to 18's.
Old Mar 29, 2010 | 11:06 AM
JumpingJackFlash's Avatar
JumpingJackFlash
My old '02 MCS had 205/40/R17s. Combine that with a dropped KW suspension, and the ride was rough (but stiff, and it cornered excellent). I later changed it out for a Koni Stage 3 kit, and that helped smooth out the ride (though it was back to stock suspension height, and the springs were not adjustable).
The best balance would probably be the factory size of 205/45/R17s. That's what I have now, and that extra little sidewall seems to make a big difference.
Old Mar 29, 2010 | 05:25 PM
nickster's Avatar
nickster
Thanks guys for the the tip!!! Now I'm more incline to choose 17" since my priority is more of the comfort ride. Guess I'm getting old. If I place 215/45/17, would it have the same wheel gap from the fender as oppose to having the stock or would it lessen? Having a bigger wheel with a wide gap might look like an AWD!
Old Mar 29, 2010 | 05:46 PM
veggivet's Avatar
veggivet
Any 17" wheel is going to fill up the wheel well nicely and either size tire should not give the AWD look.
Old Mar 29, 2010 | 07:46 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
16" wheels for smoother ride and better performance. !7" or 18" for bling.
Old Mar 29, 2010 | 07:48 PM
veggivet's Avatar
veggivet
Yup, but the options given were 17 or 18's.
Old Mar 30, 2010 | 06:04 AM
JumpingJackFlash
This involves math, so get your aspirin ready.
Gap will shrink slightly with each 17" size increase. For 205/45/R17s, take 205 x .45 to get 92.25mm of sidewall (of which some may be behind the rim edge to get the bead). 1" is roughly 25.4mm. 92.25 / 25.4 is about 3.63".
So, overall diameter is: 17 + (3.63 * 2) = 24.26"
For 215/45/R17s, it's 96.75mm, a 4mm increase (which is roughly 3/16"):
96.75 / 25.4 = 3.81
17 + (3.81 * 2) = 24.62"
215/50/R17s would be 107.5mm, which is about another 1/2" on top of that:
107.5 / 25.4 = 4.23
17 + (4.23 * 2) = 25.46"
Old Mar 30, 2010 | 06:23 AM
nickster's Avatar
nickster
Cool! Jumpingjackflash sure gave me a dose of the technical aspect! With all your best advice, 215/45/R17 + koni fsd shocks fits my taste! Thanks guys! Vroomvroom!!!
Kimolaoha
Dec 5, 2020 09:32 PM
IrishMCS
Sep 15, 2015 05:43 AM
TJANK
Aug 24, 2015 06:11 PM
sandtoast500
Tires, Wheels, & Brakes
25
Dec 29, 2004 12:05 PM
bulldog_mini
Sep 23, 2003 02:28 PM
