Front wheel play/safety
Old Mar 28, 2010 | 08:57 AM
jtpryan
I have an 02 S that just flipped 200k. The right front wheel has a small bit of play in it if you grab the top and bottom and rock it. This play exists with the wheel off and grabbing the rotor, so it isn't a lug nut issue. I suspect the wheel bearing.
Anyway my dilema is the safety at this point. I happen to have an appointment Tuesday morning at Mini to go over it and evaluate what it needs at 200k. But I need to drive ~100 miles tomorrow on the highway, then ~40 miles (highway) to the dealer Tuesday morning. I'm wondering if it would be wise to wait until then to have it worked on, or have a local guy take a look at it tomorrow morning. I inspected the various suspension points and all looks well otherwise.
Thoughts? No legal liability attached
-Jim
Old Mar 28, 2010 | 09:21 AM
Puma|Mini's Avatar
Puma|Mini
Check your front control arm bushings. I've got a similar (if not identical) issue and that's my problem. If you haven't replaced them yet, you're due.
Old Mar 28, 2010 | 10:11 AM
NightFlyR's Avatar
NightFlyR
I just failed inspection 2 weeks ago for that same problem, but it was my tie rod end
Old Mar 28, 2010 | 10:55 AM
jtpryan
So were any of these scenarios a critical safety issue for the next 200 miles?
-Jim
Old Mar 28, 2010 | 03:13 PM
NightFlyR's Avatar
NightFlyR
I changed mine out the next day, did not want to take the chance of getting stuck on the road
Old Mar 28, 2010 | 07:39 PM
Puma|Mini's Avatar
Puma|Mini
Swap 'em soon. I never stray more than 10 miles from home so I'm waiting a bit before doing it, but you should deffo swap them as soon as you can.
thebordella
Aug 31, 2015 01:37 PM
JPMontes3
Aug 23, 2015 01:26 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
