17X8 wheel on MCS, any body use it?
Old Nov 20, 2003 | 01:34 AM
Cypher's Avatar
Cypher
Anybody using 17x8 on their wheel... how is the offset ?
35/40 ??
is it rubbing??
thanks...
daniel-
Old Nov 20, 2003 | 10:36 AM
Alex@tirerack's Avatar
Alex@tirerack
>>35/40 ??
>>is it rubbing??
>>thanks...
>>daniel-
8 inch width is agressive, you'll need a higher offset
Old Nov 20, 2003 | 10:45 AM
twstlvr's Avatar
twstlvr
Cypher,
The only wheel I know of in 8" was the Hamann HM4. I ran these for about 6 months and had rubbing issues with the H-Sport springs. I used a 215/40-17 tire and had to modify the rear wheel wells to avoid continued rubbing. I believe the offset was 43MM but the 8" wide width caused all of my issues. I would recommend not exceeding the 7.5" wide wheel. I sold these wheels to Ryan (red03miniS) but I haven't seen him on this forum for some time now. Are you considering the Hamann's or did you find another wheel in this width?
Jason
Old Nov 20, 2003 | 11:01 AM
Cypher's Avatar
Cypher
Yes I am considering the Hamann...
I might switch to Breyton, if there'r too much rubbing...
Breyton Magic Sport Mini (18x7)
I don't know it Breyton would cause rub or not...
daniel-
Old Nov 20, 2003 | 11:56 AM
twstlvr's Avatar
twstlvr
Cypher,
The 7" width on the 18" wheel shouldn't cause any problems at all. Just be careful on the offset. Plenty of people using the 18" wheels with no problems. The only complaint I've heard of is ride and increased risk of bending a rim. I would tell you to stay away from the HM4's. I wasn't too crazy about the issues I had and I remember Ryan having rubbing issues with stock springs as well.
Good Luck!
Jason
Old Nov 20, 2003 | 01:14 PM
Cypher's Avatar
Cypher
Jason,
Did you lowered the car?
coz I am planning to put coilovers on it.
(either koni or KW)
but still not decided which brand
thanks
daniel-
Old Nov 20, 2003 | 02:38 PM
twstlvr's Avatar
twstlvr
Cypher,
I have the H-Sport springs. You shouldn't have the issues I've had with coilovers.
Jason
eatsleepautox
Oct 30, 2015 06:46 AM
minipopkart
Aug 13, 2015 05:22 AM
dyeLucky
Aug 7, 2015 07:10 AM
