Head removal
Old Mar 13, 2010 | 03:45 PM
Tuffcity's Avatar
Tuffcity
Head removal
About 10 days ago, the evening before leaving on vacation, my wife phones me and says that the engine in her mini is making a "banging" noise and she has pulled it over on the side of the road near our home.
Fearing the worst ( broken pistol, con rod etc) I went to have a look at it and found that the #1 spark plug had popped out. The threads on the plug were damaged and a new plug won't even start to thread. Had it towed home and now the fun begins.
I don't want to attempt a re-thread with the head still on the block but having never pulled a mini apart I'm curious if there are any surprises to removal, or things I need to be aware of before I take it off. It looks fairly straight forward but...
Any help/ info very much appreciated.
cheers,
RC
... I found the thread about the helicoil insert - I guess I might have to go that route?
Old Mar 13, 2010 | 03:53 PM
moreorless's Avatar
moreorless
The helicoil has been the first step for most folks faced with this issue. When done with care it's an excellent fix.
Old Mar 13, 2010 | 04:45 PM
Dr Obnxs's Avatar
Dr Obnxs
Yanking the head isn't hard
just take your time....
Matt
Old Mar 15, 2010 | 11:59 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I have heard stories of blowing out plugs on boosted motors. Not sure if that's what you have. I occasionally get out the 'ol 5/8 socket, extension, and wrench and check them for that reason. Definitely something to do if you have a pulley upgrade, tune, etc.
If the plug won't go in, at least consider retapping the spark plug socket if the remaining threads appear to be intact. With either that or the helicoil approach, if you do choose to leave the head on, be mindful of shavings falling into the combustion chamber. Have a small light and a long, thin magnet handy with a flexible head on it.
The one thing that comes to mind is to make sure to mark where the sprockets line up for the timing chain. You can even rotate the assembly to get the marks to line up (all sprocket gears should have them). Reference a Bentley manual if you have one (or go buy one).
Last edited by JumpingJackFlash; Mar 15, 2010 at 12:01 PM. Reason: Updated info for removing head
Old Mar 15, 2010 | 12:06 PM
Dr Obnxs's Avatar
Dr Obnxs
Magnet won't work on Al shavings
The best trick I heard was to put some panty hose in the cylinder. When you tap the head, the shavings stick to the panty hose when you pull them back out!
Pretty cool, huh?
Matt
Old Mar 15, 2010 | 12:18 PM
JumpingJackFlash
Dr Obnxs... good tip!
Old Mar 15, 2010 | 05:20 PM
Tuffcity's Avatar
Tuffcity
Thanks guys. It's a non boosted engine with no mods- kind of surprised me that the plug came loose as the others are still tight (I retorqued them anyway) A new plug wouldn't thread and when I put a bore light down there I can see thread so I'm going to try a retap first. I'll let you know how the pantyhose thing works out. I'm also going to rig a "straw" for the shop vac and try that too.
Old Mar 21, 2010 | 07:20 PM
Tuffcity's Avatar
Tuffcity
Update. Tried the re-tap but there isn't enough thread left to hold the plug tight.
Ended up having some one put in a helicoil- it's all good now.
RC
.... all work done with the head in place.
Old Mar 22, 2010 | 12:56 PM
JumpingJackFlash
Thanks for the update.
Old Mar 22, 2010 | 09:34 PM
Vernon29RW's Avatar
Vernon29RW
glad to hear it all worked out for you. After I had a plug pop out of my car, I also had a heli coil installed with the head on and it got back up and running but ever since then I've had a severe hesitation past half throttle happening in all gears. Its been very frustrating and I cannot figure out what it could be. Anyways just glad to hear it all worked out for you. Some of us (well at least me) haven't been as lucky
Steve
Old Mar 23, 2010 | 10:59 AM
rsvp9146's Avatar
rsvp9146
what you need is a Time-sert.
http://www.timesert.com/
Old Mar 23, 2010 | 12:37 PM
plasticknives's Avatar
plasticknives
I have a Big-Sert kit with a 16.8mm insert for sale if anyone needs it to repair a blown out helicoil. It's only been used once.
Old Mar 24, 2010 | 06:22 PM
Vernon29RW's Avatar
Vernon29RW
I dont know if that was at me but I messed up my terminology, I had a time-sert installed as well, my mistake
Old Mar 24, 2010 | 09:06 PM
rsvp9146's Avatar
rsvp9146
I meant it for the original poster. Sorry. I should have explained a bit more.
Time serts are a little different than Heli-coils. Heli-coils are good for low stress applications, but not what I would use for a spark plug. A Heli-coil uses a coil of threads with a tang at the end that must be broken off. You would then have to retrieve the tang and also the metal from threading the hole from inside the cylinder.
A Time-sert is a self-locking solid insert. They work very well under compression and expansion forces. In the Porsche world, they are commonly used for head stud repair on 911 aluminum and magnesium engine cases. As the engine ages, the head studs heat cycle and expand, til eventually it snaps, or it strips out of the case. During rebuilds, they replace the stud and Time-sert the hole for added strength.
I helped a friend fix a stripped out glow plug on an old Mercedes diesel. A lot more compression than the MINI's engine and it works fine.
As for Vernon,
I would maybe do a compression check on the cylinder. See if it's within range of the others. Does this happen when the engine is cold? How long has it been happening? Codes thrown?
Old Mar 24, 2010 | 09:12 PM
plasticknives
Time serts are a little different than Heli-coils. Heli-coils are good for low stress applications, but not what I would use for a spark plug. A Heli-coil uses a coil of threads with a tang at the end that must be broken off. You would then have to retrieve the tang from inside the cylinder. Good, but not for this application...
Actually there is a specific helicoil for spark plugs. They are solid inserts, not coiled, and don't use a tang. There is a tool to push the upper-outer threads, which are ribbed, into the head to hold it in place. Not really ideal, but works as a temp fix. Here is a picture:
I personally would no trust a helicoil for the sp hole, I would go straight to a Time-Sert. It's light years ahead of the Helicoil. Cuts a new seat, no way of it backing out. It's really ideal.
Old Mar 24, 2010 | 09:25 PM
rsvp9146's Avatar
rsvp9146
Learn something new every day. The locking method on that seems less than ideal. Seriously though, the Time-sert is well worth it.
Old Jul 26, 2010 | 08:42 PM
veggivet's Avatar
veggivet
My R53 just blew out #2 spark plug today at the track. I really don't want to take the head off, but I don't want shavings in the engine, either. I will tell my mechanic to use the panty hose trick referenced by Matt (Dr. Obnoxious) above, and will probably go with the Time-sert. Car only has 32k on it, and a total of about 20-25 track dates. Plugs were not changed that recently. What is the proper torque for them?
Old Jul 27, 2010 | 11:30 AM
Dinan604's Avatar
Dinan604
Proper torque is 18-21.6 ft-lbs.
Old Jul 27, 2010 | 03:49 PM
Dr Obnxs's Avatar
Dr Obnxs
I go to the high end
22-25 ft-lbs....
Matt
Old Oct 28, 2010 | 06:32 AM
motoko's Avatar
motoko
I had a time sert put on cylinder 2 last week at a local machinist referred to me by the dealer. I was looking at the engine yesterday for the first time since the job and noticed that the boot on cylinder 2 was sticking up. I feared the worst that the spark plug had blown out again (my car had just put itself in limp mode). However when I went to push the boot down, I noticed that it was already clicked onto the plug. And it just seemed as if the spark plug was sitting higher.
Is it normal for the spark plug to sit higher up after a time sert job? It seems odd to me. I called and asked the shop and they said bring it in and they'll take a look Friday.
Old Feb 24, 2016 | 12:54 PM
WTMF's Avatar
WTMF
Big Sert kit 5141S for sale still?
plasticknives,
Do you still have the Big Sert 5141S for sale?
"I have a Big-Sert kit with a 16.8mm insert for sale if anyone needs it to repair a blown out helicoil. It's only been used once."
Thanks, Mike
eatsleepautox
Oct 30, 2015 06:46 AM
greekzilla
Aug 23, 2015 03:44 PM
Aug 19, 2015 12:51 PM
wind715
Aug 11, 2015 07:56 AM
MIminiclubman
Aug 5, 2015 09:14 PM
