Suspension "bumpy" acceleration after spring install..
Old Mar 6, 2010 | 06:55 PM
mgwatson's Avatar
mgwatson
So I just finished installing a set of m7 lowering springs and I'm noticing that when accelerating, the car feels "bumpy". This is only when accelerating and not when cruising at a constant speed. I've cut all the bump stops in half and am currently running my winter tires (185/65/15). An alignment was done as well. Is there a possibility that I've made a simple mistake in installation? Everything felt solid when putting back together... any help would be appreciated thanks!
also, when retightening the top nut on one of the front struts i used an impact gun and ended up spinning the shock arm really fast for a second by accident... could this have damaged the shock?
Old Mar 6, 2010 | 08:45 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Did you happen to use an air gun to tighten the three nuts on each of the front strut towers ?
Hope not......
Old Mar 7, 2010 | 12:14 AM
mgwatson's Avatar
mgwatson
naw, i did every other bolt by hand
Old Mar 7, 2010 | 11:18 AM
broadwayline's Avatar
broadwayline
Its the driveshafts/CV, common issue on lowered MINIs.
Nothing to worry about for now.
Mines done it for 40 000km.
Old Mar 7, 2010 | 11:42 AM
mgwatson's Avatar
mgwatson
how can you be so sure? I'm thinking I wrecked a shock by spinning the piston arm on the shock verrrry fast with the impact gun by accident. If it is the driveshaFts, would it go away if I put stock springs back on?
Old Mar 7, 2010 | 11:47 AM
miniconcarne's Avatar
miniconcarne
Mine does this also.
I have H&R coilovers so it's not my "shocks". I would suspect your problem
will go away with the stock springs.
Old Mar 16, 2010 | 01:13 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Mine too! Anyone know which parts I need to order to fix it? I have a feeling mine is coming from the driver side since I watched it on the dyno.
smdmini
Oct 7, 2019 06:05 AM
nashvillemini
Sep 30, 2015 10:26 PM
thadscottmoore
Sep 25, 2015 10:07 AM
gzaos
Sep 14, 2015 04:21 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
