Help with lower control arm bushing replacement
Old Mar 6, 2010 | 12:42 AM
03chiles's Avatar
03chiles
So i bought this from pelican parts for my moms 03 mini.
I've got the lower control arm completly out of the way already. I just can't get the rear bolt on the sway bar bracket out. Easiest way looks to be to drop the whole subframe? I'm i correct? And whats the easiest way to go about doing that? I've searched and looked at most of the threads for the bushing replacement on here already aswell but none of them seem to mention this part. Or i might of just skimmed over it. Thanks in advance!
Old Mar 6, 2010 | 01:41 AM
s00perc00per's Avatar
s00perc00per
Just did this 3 days ago! search for "front sway bar DIY" or how-to. it shows you how to drop the subframe. it really is the only way to get that stupid bolt.
Old Mar 6, 2010 | 04:43 AM
ron-s mini's Avatar
ron-s mini
There are two articles in this library (may need to register/login - it is free)
One is with dropping the sub frame and one not dropping.
Not dropping is much easier.
http://www.motoringalliance.com/libr...g-subframe-62/
Old Mar 6, 2010 | 07:04 AM
s00perc00per
i thought you had to drop it if they were pre-pressed?
Old Mar 6, 2010 | 07:25 AM
ron-s mini's Avatar
ron-s mini
I do not think so -- Do you mean pressed into the carrier as in your picture?
If yes, the answer is no. Just remember if you have a 1st gen the steering linkage disconnects differently.
You may want to read post 15 on this thread:
https://www.northamericanmotoring.co...g-install.html
This is what convinced me it could be done.
s00perc00per are you coming to the HMMS meeting today?
Old Mar 6, 2010 | 07:35 AM
Dr Obnxs's Avatar
Dr Obnxs
I just dropped the subframe
it's not that hard to do. If I have to do it again maybe I'll try the "not drop" method.
Matt
Old Mar 7, 2010 | 08:21 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes even if they are prepressed you have to drop the subframe, the bolts holding the bushing carriers are too long to take out without the subframe hanging down.
Old Mar 7, 2010 | 09:03 PM
ron-s mini's Avatar
ron-s mini
Way - Just to clarify are you saying you do not have to remove the sub-frame, but you do need to at least lower it (have it hanging down) ? Thanks
Old Mar 8, 2010 | 11:51 PM
Cadenza's Avatar
Cadenza
Sounds like the instruction was written for the 2nd Gen... does it apply to 1st Gen Minis as well?
Old Mar 9, 2010 | 05:37 AM
ron-s mini's Avatar
ron-s mini
The 1st gen the steering linkage disconnects differently - otherwise they they are similar.
https://www.northamericanmotoring.com...g-install.html
Old Mar 9, 2010 | 12:36 PM
rsvp9146's Avatar
rsvp9146
I'm currently working on a Pelican technical article to go over the procedure for replacing the control arm bushings in detail. Expect it soon.
Old Mar 10, 2010 | 07:38 AM
Aeromax's Avatar
Aeromax
How soon is soon? I'm hoping to do this very soon, and I do want to do it without dropping the frame or removing the arms if possible. I'm going to use pre-pressed bushings.
Old Mar 10, 2010 | 08:31 AM
ron-s mini's Avatar
ron-s mini
If you have a Gen2 there is complete how to here:
Again the Gen1 is very much the same with the exception of the steering linkage disconnect.
Old Mar 10, 2010 | 08:50 AM
rsvp9146's Avatar
rsvp9146
I'm actually editing the text and pictures this very morning. Removing the subframe makes this job MUCH easier.
The control arm bushing brackets are torqued to over 100ft/lbs. Trying to loosen these with the subframe suspended isnt very easy. Removing the subframe and hitting them with an impact gun is much easier.
I replaced my control arm bushings with polyurethane ones
Old Mar 30, 2010 | 06:23 AM
Aeromax's Avatar
Aeromax
Do you mean the bolts that connect the bracket to the subframe? Not the bolt that connects the bracket to the car body.
Old Mar 30, 2010 | 06:28 AM
Helix13mini's Avatar
Helix13mini
No, he is saying that it's hard to remove the swaybar bolts without dropping the subframe. Even if you manage to get them loose while the subframe is hanging from the car, it's going to be a b%tch to get the bolts out, the bushings off the control arms, and the new bushings correctly on the control arms. Just drop the subframe, or better yet, take it to someone like Way to get it done. It's one of those not-so-fun DIY jobs.
Old Mar 31, 2010 | 05:11 PM
ndylam's Avatar
ndylam
I'm having a hard time removing the brackets. I tried the 3 jaw pullers but that isn't going anywhere. It's so frustrating. How did you guys removed the brackets ?
Old Mar 31, 2010 | 05:30 PM
ron-s mini's Avatar
ron-s mini
What problem are you having with the 3 jaw puller?
If the center shaft is "walking" on you try placing a small socket over the point.
Old Mar 31, 2010 | 06:39 PM
ndylam's Avatar
ndylam
it keeps slipping off the brackets. I rent a posi lock puller and hopefully I can remove the stubborn brackets off. Like Helix13mini said, this is "not-so-fun DIY." I would never touch this part again !!!
How much Torque did you torque all the bolts ? It seems impossible to torque the inner swaybar bolts.
Old Mar 31, 2010 | 09:03 PM
ron-s mini's Avatar
ron-s mini
This is a a "not-so-fun" DIY
Sounds like you need a better puller -- you will get it.
As far as torque I use this thread from K-Huevo (he has forgot more than I know about a MINI)
Old Apr 1, 2010 | 06:07 AM
Aeromax's Avatar
Aeromax
I hammered every bolt on with an impact wrench. It was the only way I was going to get anything on near 122ft/lbs.
Old Apr 1, 2010 | 09:00 AM
Dr Obnxs's Avatar
Dr Obnxs
Dropping the subframe is hard the first time...
but it's really easy after that. I'd wager that the hassle of doing work with the subframe still attached is greater than than hassle of dropping the subframe off the car in the first place.
Matt
Old Apr 1, 2010 | 11:05 AM
Aeromax's Avatar
Aeromax
I had a really easy time dropping the subframe last night. Getting the old bushings off the arms, separating outer ball joints from the steering knuckle with 105,000 miles on them, and getting the subframe back under the car in it's proper place- not so much.
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
