Suspension Vmaxx, need spacers?
Old Feb 25, 2010 | 08:03 PM
dustinhxc's Avatar
dustinhxc
I have stock S Lite wheels 16" and I am going to be getting the Vmaxx Coilovers soon. What size spacers do I need to Slam this baby 2"+ ?
16mm or is 12mm enough? Also do I need anything else? Thanks.
Old Feb 25, 2010 | 10:30 PM
JohnnyVillan's Avatar
JohnnyVillan
Whats the wheel width and offset and what tire size are you running?
My inner sidewalls up front rubbed on the adjustment ring on the strut and carved in a neat little trench all the way around the tire.
My specs were 16x6.5 +48 with a 195/55/16 tire. I would say a 5mm spacer would have done the trick. I just switched to a way lower offset wheel tho so I cant say for sure. 12mm would be more than enough.
Old Feb 26, 2010 | 09:48 AM
dustinhxc's Avatar
dustinhxc
That sounds about right but I will check them today. So the 16 would rub too much. 12 is prob the way to go im thinking. Thank You!
Old Feb 26, 2010 | 11:30 AM
dustinhxc's Avatar
dustinhxc
195/55/16 not sure how to measure camber.
Old Feb 26, 2010 | 07:49 PM
JohnnyVillan
12 will probably be good. I honestly dont know how much clearance you're gonna have with the fender but that'll all depend on how low you go.
You'll definitely tear up your inner sidewalls without a spacer
Old Oct 19, 2010 | 06:18 PM
kcle730's Avatar
kcle730
Hey guys, i noe this is a pretty old thread, but i'm getting some Vmaxx by the end of this month *woot woot* and i'm also getting some Volks TE37 ;D and i wanna noe if they wud clear? the Volks are gonna be 16x7 with ET38 with some Falken Azenis 215-45-16
Thanks!
YaTuSabe
Aug 23, 2018 11:41 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
RIchard Nguyen
Sep 14, 2015 02:45 PM
RIchard Nguyen
Sep 14, 2015 01:02 PM
