R50/53 Need a spare tire for my MCS
Old Feb 13, 2010 | 03:01 PM
minirooferS's Avatar
minirooferS
Unfortunately Ive had really shitty luck with my car and flat tires. Ive been through 5 flats since I got the car in March of 09. The front tires are no longer run flats and eventually Im going to replace the rear run flats with the same ones up front. So what Im going to do is get a rim and just leave it in my rear hatch and use it as a spare. Im thinking of just getting a stock Mini wheel off of a base model.
Does anyone know what the name of that steel looking Mini wheel off of the base model Mini's? I think its a 15' and has circular holes. It sort of looks like an old school VW steelie rim.
Old Feb 13, 2010 | 09:04 PM
Mini Mania's Avatar
you might consider one of these:
http://new.minimania.com/web/Item/NMW7610/InvDetail.cfm
Old Feb 14, 2010 | 06:55 AM
buzzsaw's Avatar
buzzsaw
It appears that the donut spare on the 95-98 VW Jetta, 82-89 Honda Accord and the 01-02 Honda Civic has the same offset, hubsnout, bolt pattern and bolt size as the 1st gen Mini. If that is the case I will purchase one from a salvage yard when I ditch my runflats. I have found that prices range below $50. FWIW.
Old Feb 14, 2010 | 08:58 AM
JAB 67's Avatar
JAB 67
MiniRooferS: You are inviting trouble by mixing runflats with nonrunflats at the same time.
kazyn
Oct 25, 2019 02:34 PM
madmax88
Aug 21, 2017 07:07 PM
TJANK
Aug 24, 2015 06:11 PM
col127
Aug 21, 2015 02:11 PM
Mrdi
Aug 7, 2015 01:06 PM
