Spark plug torque spec?
Old Nov 11, 2003 | 12:37 PM
friedduck's Avatar
friedduck
I'm changing plugs--anyone have the torque spec handy for these? (I'm assuming it's a low value w/alum. heads--don't want to overdo it!)
TIA,
Jeff
ps: yeah--I searched--couldn't find any reference tho I know it's in here somewhere
Old Nov 11, 2003 | 01:11 PM
8ball's Avatar
8ball
that should be 27nm (ungreased) ... and don't forget the never-seize!
There is a Factory tool, btw, that has the proper sized socket and an attachment that they call a "torque limiter" , just in case your garage doesn't have a torque wrench!
Old Nov 12, 2003 | 05:38 AM
friedduck's Avatar
friedduck
Thanks much--where do you find this stuff, btw? I can't believe how little info. is available.
That's actually higher than I thought it would be. Any good rule-of-thumb for how much to compensate for adding anti-seize? (I always use this stuff on plugs. I hear ti-to-ti is even more prone to welding itself together.)
Jeff
_________________
Jeff in ATL
Old Nov 12, 2003 | 03:56 PM
friedduck's Avatar
friedduck
After some digging, here's Denso's recommendations (below). There's a lot of net-wisdom about what we ought to reduce torque values by when applying anti-seize--obviously no consensus.
http://www.densoiridium.com/installationguide.htm
rob76turbo
Sep 15, 2015 10:11 AM
Sep 4, 2015 03:56 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
cw40342
Sep 2, 2015 06:01 AM
