Cooper (non S) Modifications specific to the MINI Cooper (R50).
Help tyre and suspension question
Old Jan 19, 2010 | 01:10 AM
Rors's Avatar
Rors
Hi Guys
I have a 2004 mini Cooper with chilli pack, i have just purchased the S lite 17 Cooper S Mag set.
I need to know the following.
1.Will I need to drop the suspension, in order to maintain the distance from tyre to arch and not have a huge gap?
2.I have been told by fitters that i cannot fit standard 205/45/R17 tyres to these mags and they have to be run flat tyres only! I feel they are trying their luck?
Please help
Old Jan 19, 2010 | 01:15 AM
Oxybluecoop's Avatar
Oxybluecoop
Yes the gap will be significant so I would recommend lowering springs or a coilover system. As far as what tyres you can mount they can be ANY compatible tire regardless if it is a runflat or not.
Old Jan 19, 2010 | 01:23 AM
Rors's Avatar
Rors
Cool , thanks for the help
Old Jan 19, 2010 | 12:34 PM
MiniGB06's Avatar
MiniGB06
Why is this the case on r50s with 17s?
Old Jan 22, 2010 | 07:29 AM
101101's Avatar
101101
As long as the outer diameter (O.D.) of the new tires is the same as the O.D. of the old ones the wheel gap would be the same. Changing the wheel diameter might make it appear to be more or less of a gap, the the actual measurement would be the same.
You probably were told the run-flat thing because only MCS came with the 17s and they only came in run-flat variety from the factoy. The MC came with a spare, so if you're comfortable with possibly needing to change a flat tire on the side of the road then keep the spare and use non run flats.
twistedimages
Sep 19, 2024 04:13 AM
silence2-38554
Nov 12, 2015 09:39 AM
Kahnfucious
Aug 15, 2015 08:43 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
