Suspension Springs aren't settling, what's wrong?
Old Jan 17, 2010 | 02:58 PM
SAM.MAY's Avatar
SAM.MAY
So 2 weekends ago, my friend and I installed my new H&R springs k-huevo's how-to post. The driver's side looks normal/right, but the passenger side isn't settling and is higher than the stock height. Is that fixable?? The right springs are in the right spots.. what to do next??
Here are some pics (sorry for the quality):
Driver side:
Passenger side:
Front driver:
Front passenger:
Rear driver:
Rear passenger:
Old Jan 17, 2010 | 07:19 PM
rjtrout2000's Avatar
rjtrout2000
How long has it been? Two weeks isn't enough time to let stuff settle. Mine took about two months fyi
Old Jan 17, 2010 | 08:59 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
There's some settling, but that front passenger side looks like it was re-assembled incorrectly or the spring isn't seated correctly or something. Cars only settle a little bit.
Best bet is to take off the front passenger strut and make sure you put it all back together correctly. There's something definitely wrong beyond just settling.
Old Jan 17, 2010 | 09:55 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I'd say there may be something wrong. Usually the H&R's slam the car down and yours is sitting pretty high.
Old Jan 18, 2010 | 11:37 AM
DaveVT02S's Avatar
DaveVT02S
+1 - and probably before you drive it very far - somethin' ain't right...
And looks a little high all the way around w/ stock-size 16" tires, but that could be me :dunno: ...
Old Jan 18, 2010 | 12:14 PM
Rally@StanceDesign
Yup even driver side front looks too high for H&R's. I'd check all corners
Old Jan 18, 2010 | 01:56 PM
xxTHIR13ENxx's Avatar
xxTHIR13ENxx
I'd second what everybody has already said. My car on H&R looked pretty low soon as the install was done. After two weeks, it had settled nicely (I drive quite a bit), and has been pretty much in the same height since.
Good luck,
Leo.
Old Jan 19, 2010 | 09:08 PM
SAM.MAY's Avatar
SAM.MAY
hmm alrighty thanks for all the advice! another quick question, is it normal that the springs came green? cause i know that normally h&r's are usually black or red? but yeah definitely i'll re-check everything asap
Old Jan 19, 2010 | 09:16 PM
Rally@StanceDesign
H&R's are often green. 90% of the MINI H&R springs I've seen have been green. I've only seen a few sets of red.
Old Jan 19, 2010 | 09:17 PM
DaveVT02S's Avatar
DaveVT02S
Your OP said "new"; where did you get them? (I guess I'm asking "new" or "new to you / used"?)
Old Jan 21, 2010 | 03:26 AM
SAM.MAY's Avatar
SAM.MAY
alright thanks stancedesign. but yeah i got them at an online store which got them straight from H&R brand new
Old Jan 21, 2010 | 06:43 AM
Helix13mini's Avatar
Helix13mini
H&R uses a pre-sagging technique they call something like Blok Setting, which all but eliminates spring settling once they are on the car. There may be some bushing movement which can settle the car a little bit, but, I think you have an installation problem. Also check the serial numbers on the coils of the springs. I think they are upside down on the H&Rs but you should be able to read them with a little neck craining. Verify that they are consistent and that they are for your application.
Filmy
15
Jun 6, 2023 06:27 AM
smdmini
Oct 7, 2019 06:05 AM
ej
Nov 17, 2015 09:21 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Sep 4, 2015 01:32 PM
