Suspension time for a more aggressive set up
Old Jan 4, 2010 | 11:08 AM
KandyRedCoi's Avatar
KandyRedCoi
i need your opinions, suggestions and expertise on my next susp set-up
the car will see occasional canyon, auto-x and track days
i recently purchased a set of H&R sport springs for my car before doing any research, and i really didnt like it so im here now to see what you guys/gals to help me with my decision
coilovers - will let me fine tune exactly how low my car will go, and it will give me the option of corner balancing, just cant decide which set-up i want to go with: megan or vmaxx or tein basics???
front camber plates - well i know these will help give more adjustability with the front camber of the car, but i also learned that some of them actually make the car "higher" and i personally dont want that, any suggestions on which brand to go with?
sway bars - i read some people only put the rears, any reason why the front sway bars dont need to be changed? or should i just do front AND rear??? which brand???
wheels & tires - currently i have 16" 5zigen pro-racers, and falken fk415 tires, can you suggest how aggressive i can go size wise on a 16" wheel tire set-up, i dont want to go 17" or bigger...and what the stickiest all season tires you can suggest???
and last thing
alignment set-up - just a quick general info on how to set the alignment camber toe etc. on the car so when i get all these items i can have my guy make sure the car is tracking true and straight
thank you!
Old Jan 4, 2010 | 04:56 PM
Longboard110's Avatar
Longboard110
if you plan on doing autocross, first find out which class you want to run in and set up your car according to the rules.
Old Jan 4, 2010 | 05:02 PM
Alpha Motoring's Avatar
Alpha Motoring
you forgot control arms! very important if you want to build up your suspension!
Old Jan 4, 2010 | 05:03 PM
veggivet's Avatar
veggivet
Most performance alignment setups dial in negative camber, anywhere between -1 and -3, depending on how aggressive you want to be on the twisties. Most of us trackheads run with the rear sway bar. If you decide to add rear control arms, check the reviews on this site, and beware of ALTA's reputation for clunking.
Old Jan 5, 2010 | 01:49 AM
KandyRedCoi
thanx for the 411 so far everyone!
i do it for fun, im not going to compete, but i want the car to be more capable than stock
i will also look into rear control arms...thank you!
Old Jan 5, 2010 | 06:27 AM
Longboard110
give tsw a call, they can set you up then
Old Jan 5, 2010 | 10:49 AM
KandyRedCoi
^got a link?
Old Jan 5, 2010 | 03:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
There are so many options. You def should get a rear swaybar. Feel free to give us a call and I'll set you up. We'll give you some options.
WAY
317.201.8670
www.waymotorworks.com
Old Jan 5, 2010 | 06:35 PM
KandyRedCoi
^gonna ck out your site now
thanx!
Old Jan 5, 2010 | 06:44 PM
KandyRedCoi
im probably gonna go with v-maxx coilovers
not sure which camber plates, control arms, and rear sway bar to go with
any suggestions?
Old Jan 5, 2010 | 07:17 PM
andyroo's Avatar
andyroo
I'm under the impression that v-maxx coilovers are more for looks than performance?
Old Jan 5, 2010 | 09:44 PM
WayMotorWorks
Vendor
any suggestions?
You can't go wrong with the Hsport control arms, or swaybars They are the BEST available.
As for the others use and application are key.
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
flredmini
Aug 12, 2015 06:35 PM
wind715
Aug 11, 2015 07:56 AM
