R55 Replacement wiper options?
Old Jan 3, 2010 | 06:42 PM
CulexPipiens's Avatar
CulexPipiens
Hi. My wife got her 2009 Clubman back in April of 09 and I got mine just a few days ago. In both cases we're not happy with the factory wipers. Mine, pretty much from the very first time I used them, are streaky. My wife has experienced similar issues on hers.
I can find some options pretty easily however I'm looking for feedback from someone who has used them. So, any recommendations for after market wipers? something that works well in Chicago winters?
-Gary
Old Jan 3, 2010 | 07:15 PM
bad venge's Avatar
bad venge
I recomend Aquapel treatment on the windsheild first
(it's like RainX but lasts for a year)
for aftermarket wipers I've been using latitude ones
Old Jan 3, 2010 | 07:18 PM
trico's Avatar
trico
+1 on RainX, Aquapel or the 3M equivalent. I use Bosch wipers on mine.
Old Jan 3, 2010 | 07:22 PM
malteseracer's Avatar
malteseracer
been hating mine too. They are 19" right and 18" left correct? I'd measure but its cold :P
Old Jan 3, 2010 | 07:33 PM
Tron Chief's Avatar
Tron Chief
I put Piaa on my wifes and she loves them
Old Jan 3, 2010 | 07:38 PM
dwdyer's Avatar
dwdyer
I went with 18" Bosch Icons on my 07 MCS, and I like them. No way to really test winter use though for me.
Old Jan 4, 2010 | 08:05 AM
Bigshot's Avatar
Bigshot
Try to clean the window and wipers first then treat them and see how they work. Then get new wipers if needed.
I love my sillblades with the five year warranty.
Old Jan 4, 2010 | 09:32 AM
driverphil's Avatar
driverphil
Aquapel is good stuff. Our local Costco has it too!
Old Jan 4, 2010 | 12:51 PM
CulexPipiens
Thanks for the replies so far. I've got a partial bottle of RainX at home and since the car is only a few days old I haven't had a chance to apply it yet. I'll start with that and consider the Aquapel stuff when I use the RainX up.
My local car parts place stocks Bosch so I'll see what other recommendations I get but so far they look promising. I had a set of them on my previous vehicle (Civic) and they worked well but I didn't know if the same performance would carry over on the MINIs.
Old Jan 4, 2010 | 03:18 PM
Bigshot's Avatar
Bigshot
Make sure the winshield is as clean as you can get BEFORE putting anything on it.
Old Jan 5, 2010 | 08:46 AM
Xeraux's Avatar
Xeraux
Yep.
Goodyear Assurance "Bracketless" Wiper Blades.
I put these on the minute I got my new Clubman home.
About US$13.00 a blade at Costco.
They work well.
I believe the RainX Latitude,
Michelin Symphony,
Bosch Icon,
and Goodyear Assurance are all rebadged versions of the same "bracketless" blade.
Old Jan 5, 2010 | 01:36 PM
isthar's Avatar
isthar
My 2 cents:
1) I stay away from rain-x until you find out you have to use it; I find that once you start using it, that's it, it's on your windshield forever
2) on my old car, I bought the Piaa silicone sport wipers. WOW those were so smooth on the windshield...
For my mini so far, I find the wipers OK. Note that I have the heated nozzles, so that might help things in the cold weather?
Old Jan 5, 2010 | 02:20 PM
Capt_bj's Avatar
Capt_bj
CLEAN CLEAN CLEAN
Originally Posted by Bigshot
Make sure the windshield is as clean as you can get BEFORE putting anything on it.
which means use your clay bar if you are a clay person or using a single edge razor blade to run ALL the glass. U L B amazed how much stuff U pick up ... THEN clean well with an ammonia strong wash (windex)
I run my glass with a razor every 6 months and ALWAYS pick up crud
Old Jan 5, 2010 | 07:58 PM
Shoof's Avatar
Shoof
FYI, here is another link related to your question: https://www.northamericanmotoring.co...ld-wipers.html
I switched my wipers out to a cheap set just so they can wipe better than the stock ones (took them from my friend's shop), and when I took my car in for service last week, swapped the OEM wipers back on and told the dealer to replace them, so they did it. They are OK so far..
Old Jan 6, 2010 | 03:34 PM
schatzy62's Avatar
schatzy62
Here is another option for the cold weather climate folks.
These heat up and that way snow and ice do not collect on them when in use.
http://www.autoxcooper.com/heated_blades_order.html
Old Jan 8, 2010 | 03:43 PM
vereinmann's Avatar
vereinmann
don't bother with these if you're in a sub-zero winter climate
I gave them a try on my Mazda last winter and they harden right up, the rubber compound just doesn't seem to be meant for the cold... worked great in warm weather tho
Old Jan 8, 2010 | 08:25 PM
miniclubman's Avatar
miniclubman
My original set of OEM blades on my '08 Clubman were great, the replacement OEM blades I got last March from the dealer are not nearly as good, they streak, especially in a light rain.
I'll try OEMs one more time when I get the next oil change in March, but if they don't work out I'll have to shop aftermarket. I also need a new set of rear blades.
I wish the rear wipers had a speed setting so they didn't end up wiping a nearly dry window all the time. Maybe the next gen Clubman will have that feature.
Old Feb 22, 2011 | 02:15 PM
Prost's Avatar
Prost
Originally Posted by Xeraux
Yep.
They work well.
Michelin Symphony,
Bosch Icon,
Just got a pair of Goodyear Assurance from Costco over the weekend...what a day and night difference compare to the stock one...took me 5 minutes to install both and at $7.99 each...nothing can beat that
Old Feb 23, 2011 | 01:07 PM
Seedyman's Avatar
Seedyman
Anyone ever replace the rear wipers? Mine started to just smear a little while ago, on one side, and it's really annoying.
Old Feb 23, 2011 | 01:41 PM
05Greenie's Avatar
05Greenie
Wiper
I have replaced my rear wiper many times and I get an OEM from WayMotorWorks...never had an issue with the performace with the rear wiper.
The front wipers are another issue...I found this thread very useful. Many options to try.
The biggest issue is finding a wiper that will remain in contact with the super curved windshield.
Old Feb 23, 2011 | 01:44 PM
MCS Fever's Avatar
MCS Fever
Rear wipers pretty much have to be from MINI is what I am thinking.......
For the fronts went with..... PIAA SUPER SILICONE CURVED..........
PIAA part numbers 93245 and 93248.........
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
