Clutch Pedal
Old Jan 3, 2010 | 08:13 AM
Flyinace2000's Avatar
Flyinace2000
Clutch Pedal
When i depress my pedal there is a spot of very mild resistance and it makes a soft click noise when i go past it. This happens with the car out of gear and has done it since mile 0. My 07 MCS did not make this noise. How worried should i be? Granted i have waited nearly 13k so far...
Old Jan 3, 2010 | 10:10 AM
KevinC's Avatar
KevinC
Sounds like the pedal return spring is wonky. Should be a simple fix, either by you looking down there and seeing if you can tweak it back into place, or by your local stealership.
Old Jan 3, 2010 | 10:27 AM
drewstermalloy's Avatar
drewstermalloy
Mine is the same way. They replaced the return spring and it didn't change anything.
Old Jan 3, 2010 | 04:11 PM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
I noticed that on my '10 MCS as well that wasn't there on the '07. The '10 has the hill-assist brake that I didn't have before, which seems to 'click' right around the same point, so I'm naturally wondering if there's a connection...?
Old Jan 3, 2010 | 07:17 PM
Porthos's Avatar
Porthos
Take it mine did something similar and they replaced the whole clutch pedal assembly. Warranty is always worth more then second guessing yourself.
Old Jan 4, 2010 | 09:22 AM
Flyinace2000
My 07 also had the hill assist so i do not think that is related. I think i will just schedule a service visit next time i am there for car wash.
Old Jan 6, 2010 | 05:29 AM
56rfixr's Avatar
56rfixr
It's either the pivot on the Clutch Master hitting in its bracket (fixed by cutting a plastic washer into a C shape and installing it on the pivot rod) or the clutch pedal itself has a portion of plastic that hits on part of the plumbing for the slave cylinder. That is fixed by grinding or filing a small portion of your clutch pedal.... I know it sounds extreme, but you'll see when you look at it. The problem with putting your head down there and using your hand to opperate the clutch, is it doesn't go at the same angle as your foot would, so its hard to re-create the noise. Good luck
drrigg
May 27, 2022 03:31 AM
scfiveo
Sep 27, 2019 02:27 PM
eliseo1981
Nov 2, 2015 11:24 AM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
