STX (Street Touring X) sway bars
Old Dec 21, 2009 | 05:54 PM
autoXmini's Avatar
autoXmini
sway bars
I'm looking to upgrade my rear sway bar. I will also be running to car in STX next year. I'm not looking to win a national championship or anything but I want to run street tires and my car will have to many mods to run G stock. I was looking at the H-Sport 25 mm bar. Is that too big for a daily driver? I'm not too concerned about the drive just performance. Would I be better off going with, say, the Alta 22 mm bar? Thanks for the help.
Old Dec 23, 2009 | 08:20 AM
istara's Avatar
istara
I run the H-sport (25.5 hollow, which I assume you're referring to?) on my daily driver / street mod MINI and have had no problems.
I'm not going to look up the exact stats on % over stock difference between the alta and the h-sport, but I imagine it's similar depending on settings and the h-sport is lighter.
Old May 7, 2010 | 01:24 AM
howsoonisnow1985's Avatar
howsoonisnow1985
I run the H-Sport 25.5 CroMolly bar on street on hardest setting, no probs.
From stock to 25.5 bar, you can rotate with abrupt throttle release in turns, no brakes required. At first I decreased psi in rears, now on hardest setting and back to higher psi in rear-now used to it.
Old May 7, 2010 | 03:00 AM
slinger688's Avatar
slinger688
I think the H sport 25.5 MM hollow bar is generally equivalent to the 22 MM size. I run 22 MM as a DD but on the softest setting. I think it is fine after I have gotten more use to it. As mentioned by howsoon, it does have a tendency for the rear end to step out on you if you are not attentive but that is easy to save in a FWD.
Old May 7, 2010 | 08:06 AM
Boxcars's Avatar
Boxcars
I run the H sport 25.5 mm hollow bar ( got it from Way Motor Works)as a daily driver in middle setting, feels GREAT!
boxcars
Old Sep 10, 2010 | 01:34 PM
13stx's Avatar
13stx
I run both H-Sport sway bars with their front camber plates and rear camber links along with TSW springs. I drive my car at least 1/2 the days to work and everything isn't too rough.
Joel
13 STX - 05 JCW
YaTuSabe
Aug 23, 2018 11:41 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
mauiguyharry
Oct 8, 2015 06:53 PM
