engine wrning light...brrrrrrrr...safe to drive?
Old Dec 18, 2009 | 04:13 AM
miniSQ's Avatar
miniSQ
I started my car this morning no problem...but then i heard it warming up and the engine was almost stalling ...and a engine light that looks like a engine block came on...the light looks like have of it is filled in with yellow.
i looked in the manual and can't find it...
Old Dec 18, 2009 | 05:15 AM
countryboyshane's Avatar
countryboyshane
You need to have it checked out by service. This is called "limp" mode. Your MINI will be operating at half power till you get the problem resolved.
If you have a OBDII code reader you can reset all check engine lights and it will go away, but if you're not finding out what's causing it you're asking for trouble down the road.
Old Dec 18, 2009 | 05:58 AM
miniSQ's Avatar
miniSQ
i turned the mini around in the driveway and pointing downhill and restarted it...no engine light, and no limp mode. It drove fine for the hour drive to work.
I will take it over to the garage this morning and see what they can pull for a code.
Old Dec 18, 2009 | 06:11 AM
Gil-galad's Avatar
Gil-galad
This thread may offer you some clues...
https://www.northamericanmotoring.co...r-startup.html
Old Dec 18, 2009 | 07:25 AM
jcoop36's Avatar
jcoop36
I had the same thing happen as I was leaving work Tuesday evening (9800 miles on the odometer). Engine ran rough, like cylinders missing, and lots of gray exhaust, then the same yellow "engine operating in reduced mode" light came on. I was able to "limp" down to the dealership, they promptly took the car in (mechanics had already left for the day) and issued me a loaner. The next day they found the fuel pump was bad and replaced it no questions.
Old Dec 18, 2009 | 01:28 PM
MINIxB's Avatar
MINIxB
Mine did it when it was 14 degrees outside. I let it warm up and then shut the car off and turned it back on and everything was fixed.
Old Dec 18, 2009 | 01:45 PM
miniSQ's Avatar
miniSQ
it was -5 here this morning....and i never got any limp mode message...just the engine black picture above the steering wheel. I drove it around al day and no problems since...
Old Dec 19, 2009 | 04:31 AM
miniSQ's Avatar
miniSQ
I am believing this to be the problem that is in the "sticky" regarding frozen throttle body...so mods can delete this topic and i will follow the sticky thread.
thanks!!
Old Dec 19, 2009 | 04:56 AM
buckbs's Avatar
buckbs
I live in the south where it does not get as cold as where you guys live, but the problem is universal whether the temps are cold or whether they are hot. I've had mine 2009 clubman s act up twice in the first 36,000 miles. Sevice people at TWO different Mini dealerships have said the a poor high pressure fuel pump is causing all of our problems and until they re-design or get another supplier, we are going to continue to have problems.
W0TM8
Dec 19, 2019 07:50 AM
David.R53
Sep 1, 2015 06:49 PM
Zettinger
Aug 25, 2015 04:04 PM
PatrikKN
Aug 5, 2015 09:10 PM
