Hub centering rings, ARGH!
Old Nov 5, 2003 | 09:34 PM
paulmon's Avatar
paulmon
I switched to my winter tires today, what a job! The centering rings for my aftermarket 17" wheels were stuck on one of the front hubs. I couldn't budge it at all! I eventually had to get nasty and get a pair of vicegrips on it, even that took some real effort, ruined that ring in the process. Does anyone know a way to prevent this? The centering rings are plastic, are alloy/aluminium centering rings available? Is it possible I got my hubs so hot at a track event that it more or less melted the plastic centering ring?
Cheers,
Paul
Old Nov 5, 2003 | 09:50 PM
cdconsor's Avatar
cdconsor
1010tires.com sells alloy rings.
Old Nov 5, 2003 | 10:05 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The centering rings are indeed hard plastic and are designed to take only so much heat. Like anything if enough heat is applied-sure it will melt and fuse. I guess the moral of the story is that you have to drive in such a way to be careful about overheating your components be it the engine, the tires, or the brakes given the equiptment you have.
When I went to driving school my instructor was very sensitive about running the car in such a way near the end of the track session to take it easy and not overheat the brakes. It's only as strong as the weakest component.
Alloy centering rings should help. I suppose a little silicon cannot be that bad on the ring as it faces the hub before you tighten things up on the wheel. Do re-tighten after 20-25 miles.
You must have been going really hard on your brakes to do this and mess up the stock rotors too.
Old Nov 5, 2003 | 10:06 PM
Ryephile's Avatar
Ryephile
I haven't heard about anyone melting their plastic hubrings, but I'm sure it's possible. Give Randy a jingle or e-mail - he uses plastic hubrings for his race wheels.
My only other thought; did you get the correct size? The MINI's hub is 56.1mm
Good luck,
Ryan
Old Nov 6, 2003 | 06:58 AM
Alex@tirerack's Avatar
Alex@tirerack
I had seen plastic rings getting melted, and plastic centercaps getting warped. Typically this is around agressive track driving - whenever possible I sub in metal rings at n/c!
Alex
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
