lost interior lighting...along with high beams and fogs???
Old Dec 6, 2009 | 09:26 AM
Barchinski's Avatar
Barchinski
Hi
So last night I was driving home and I noticed that it seemed a bit darker than usual in my mini. It took me about a minute to realize all my interior lighting was off. I had no lights on my speedometer, doors, ceiling, sides and then I checked my high-beams and they didnt work along with the fog lights. Has this ever happened to anyone before? I checked it this morning and still nothing. I'm thinking a fuse is gone but really dont know...any advice would be appreciated. Thanks in advance.
Andrew
Old Dec 6, 2009 | 06:11 PM
gregsmini's Avatar
gregsmini
I had a problem similar to yours a while back. I have my lights set-up so they are always on. I also keep the headlamp switch set to automatic. I got it back from the dealer and my interior lights and fog lights did not work.
The problem was the headlamp switch was turned off. It took me a while to figure it out since I never turn off the lights. My suggestion is to check your headlight switch on the turn signal stalk.
Old Dec 7, 2009 | 11:02 AM
Robin Casady's Avatar
Robin Casady
So, you had the daytime running lamps set to on, but auto headlights off? I don't use either with Xenons because I don't want them firing up unnecessarily. Although Xenons have a long bulb life, I've heard that the ignighters don't and are expensive to replace. Do the high beams not work with daytime running lights? If that's true, could be what happened to Barchinski.
Old Dec 8, 2009 | 12:37 AM
BensMini's Avatar
BensMini
Still might be a good idea to check the fuse box.
Old Dec 20, 2009 | 08:00 AM
Xeraux's Avatar
Xeraux
Speaking of interior lights...
Just picked up a 2010 Cooper S Clubman last night. I inadvertently held the interior light switch for three seconds or so and, according to my owner's manual, switched off my interior lights "permanently". While I'm sure it's not "permanently" as in, "never to come on again within the lifetime of this car", but "until the time as you see fit to turn them back on".
Soooo...
Can anyone tell how to turn the $*#@( things back on?
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
RACEnSK8
Aug 31, 2015 01:08 PM
Powershift
Aug 16, 2015 05:14 PM
