R55 Fresnel Lens - LightInSight - Do you like it?
Old Nov 28, 2009 | 06:48 AM
macct's Avatar
macct
With the benefit of the search function, I came across the LightInSight, a plastic fresnel lens. For those not familar with it, it's to assist in viewing traffic light signals which can be hard to see because of the Mini's roof line. For those who have tried it, did you like it or find it distracting at all? Is it out of your line of sight when driving or create any glare? thank you
Old Nov 28, 2009 | 07:02 AM
DanH's Avatar
DanH
I think it's a great assist. I recently relocated mine. I previously had it up tight against the edge of the windshield but now have moved it down so more of it is in my view.
I do not find it distracting.
Old Nov 28, 2009 | 07:57 AM
lhwelch's Avatar
lhwelch
I've had one for some time. Moved it from my R53 to the R56. Mine is located about one inch below the upper edge of the windshield and is not a distraction. It has eliminated most neck craning. The only criticism I have is that the image size is quite small, and in glare conditions it is sometimes hard to see the traffic light clearly.
I thought it was a bit overpriced, but have found it to be a great convenience.
Old Nov 28, 2009 | 08:28 AM
mjobrien's Avatar
mjobrien
I think this sums it up quite nicely.
I don't find it distracting at all during regular driving, but it's there for those times you need it. It may slightly change the time when the sun is in your eyes, but the shade covers it just like it would if the sun were at the top of your windshield.
Old Nov 28, 2009 | 08:45 AM
agranger's Avatar
agranger
I've had mine on my '06 mcs for a few years. There is nothing distracting about it and, because I'm so tall, it really helps me see the traffic lights without craning my neck.
I've got mine tucked partialy under the headliner so not all of it shows.
I'll keep it with me for a long time. Love the L-I-S.
Old Nov 28, 2009 | 09:55 AM
cristo's Avatar
cristo
Alliance Member
It's great.
Old Nov 28, 2009 | 10:14 AM
GBMINI's Avatar
GBMINI
Had one in every MINI I own, it's essential!
Old Nov 28, 2009 | 11:10 AM
lovethecorners's Avatar
lovethecorners
You'll be staring at the LIS for a few days until you get used to it (especially entertaining when driving under overhanging trees), but once you do you won't know how you lived without it.
Old Nov 28, 2009 | 11:46 AM
Gil-galad's Avatar
Gil-galad
The best mod for the money that you can make. Don't leave home without it.
Old Nov 28, 2009 | 12:22 PM
ZippyNH's Avatar
ZippyNH
If you are tall, and drive a MINI, it is highly recommended!! I use mine all the time!!
Old Nov 28, 2009 | 02:16 PM
TorchMINI's Avatar
TorchMINI
+1. The Mini windscreen is short and roof eclipsed, which I like, but the L.I.S. makes it easy to see the traffic lights. My wife, however, finds it distracting, and always pulls the sunshade over it.
Old Nov 28, 2009 | 02:39 PM
AutoXCooper.com's Avatar
AutoXCooper.com
best $15 I every spent on my MINI and after spending the last two days in my GF car I'm going to order one for hers too.
Old Nov 28, 2009 | 03:19 PM
macct's Avatar
macct
Thank you for the replies
I appreciate the feedback.
Old Nov 28, 2009 | 04:42 PM
onefish2's Avatar
onefish2
I am 6'2" and it was a real pain to see the traffic light change to green. So I wound up getting one. It took a while to sink in that the thing was there and that I should use it. Almost a year later, sometimes I still forget to use it. Even so I'd highly recommend it.
Old Nov 29, 2009 | 12:29 PM
dbhouston's Avatar
dbhouston
moved it to my 2nd Mini. Can't live without it.
Old Nov 30, 2009 | 07:19 AM
buzzsaw's Avatar
buzzsaw
+1 Don't leave home without one.
Old Nov 30, 2009 | 08:16 AM
bugeye1031's Avatar
bugeye1031
Moderator
I'm 6'2" - it should be standard equipment!
Really miss it when I drive my wife's Mini.
Old Nov 30, 2009 | 11:58 AM
Otra's Avatar
Otra
They also last "forever". Am using the same one I have had since 2003.
Old Nov 30, 2009 | 01:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I used to think these were silly, then I put a light in sight in my car and now whenever I drive another MINI I so miss it. So I have to say it's a great little item.
Old Dec 1, 2009 | 09:43 AM
SidSwiftsteel's Avatar
SidSwiftsteel
(poor attempt at humor removed to avoid further offense)
Old Dec 1, 2009 | 11:04 AM
Robin Casady's Avatar
Robin Casady
Originally Posted by SidSwiftsteel
stopping at traffic lights is overrated
So thought a late teenager in California.
I've been skeptical about the LightnSight, but just ordered one to give it a try.
Old Feb 8, 2010 | 10:30 AM
dingersdad's Avatar
dingersdad
I'm 6'5" and it has come in real handy. I tucked mine in behind the rearview mirror and traffic lights show up just fine, on the left end of it. Its totally out of normal view and occasionally the sun can be reflected thru it, but not a common occurrence.
Old Dec 18, 2013 | 05:57 AM
Justaguy's Avatar
Justaguy
I hated to revive this old post, but I had never heard of this lens before. I know they make them for motor homes - to be used in any rear window to allow visibility of back-bumper when in reverse. Thought I'd post this, maybe others could benefit as well.
Old Dec 18, 2013 | 01:01 PM
cristo's Avatar
cristo
Alliance Member
I believe they were not available for a while over the past few years,
but now they're back in stock. Still highly recommended.
Directly from http://www.lightinsight.com or through Way Motor Works
http://www.waymotorworks.com/lightinsight.html?&cat=0 .
Old Dec 18, 2013 | 01:53 PM
Michael Hayes's Avatar
Michael Hayes
Thanks for bringing this up again. I've ordered one.
