225/35/18 td 1.2 18x8 et 45
Old Nov 18, 2009 | 11:37 PM
pillar's Avatar
pillar
I was wondering if these would be a good setup... i am not looking for stretch/poke, just a more aggressive look and possibly performance gains?
I have an r56 s and am considering team dynamic pro race 1.2 18x8 et 45, with 225/35/18 tires.
1. I am pretty sure they will not rub on stock suspension. Also, if i were to drop in the future, it would be ok i presume?
2. i figured thicker rubber = more grip but somewhere in this forum, someone stated it will cause more understeer? is that possible?
3. i want to go 18s but the only size tds offer is 18x8... 45mm offset is reasonable yes?
thanks in advance
Old Nov 19, 2009 | 12:24 PM
Stig One's Avatar
Stig One
thanks in advance
Works well and no increase in understeer but limits you in tire choices. I would look at 17x8 45 et with a 235/40/17 for better selection of extreme performance tires and less unsprung weight and a better ride .
Old Nov 20, 2009 | 08:00 AM
fronjoni's Avatar
fronjoni
i have this exact setup 18x8 et45 225/35/18 and im all the way down on my h&r rss coilovers, its hella annoying sometimes because it does rub lock to lock, and the ride is really harsh from the 18's, im going with a 16x7.5 so i advise, if you are going to lower your car, do not run 18's...sacrificing quality of the ride, let alone the weight of the wheels/tires, for looks=fail, as i have failed on this setup.
you can see my gallery for how it will look if you lower on 18's.
Old Nov 20, 2009 | 12:38 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Originally Posted by Stig One
Works well and no increase in understeer but limits you in tire choices. I would look at 17x8 45 et with a 235/40/17 for better selection of extreme performance tires and less unsprung weight and a better ride.
+1
Tire size (35 series) make for a bumpy/jittery ride too.
"possibly performance gains?" Not Likely!
Better performance from what the Stig suggested, or even smaller 17x7.5 and 215/40-17 would be better than heavy 18x8s and 35 series (225/35-18) tires. Mine came stock with 18x7s, but when I need better performance I run 17x8 ET42 w/ 225/40-17 or 15x7.5 w/225/45-15.
Old Nov 20, 2009 | 01:56 PM
dooky's Avatar
dooky
you can try 215/40/18... or
225/40/18 (oxybluecoop is running these)
Old Nov 20, 2009 | 09:49 PM
pillar's Avatar
pillar
my car isnt lowered yet... and if i ever did, i dont plan on going as low fronjoni....
only reason i wanted to get low profile tires was to stay within the stock diameter. 205/45/17 is not soo much different from 225/35/18 in terms of diameter. I guess lower profile means less absorbed which means bumpy ride.
Ill be running on stock sport suspension... maybe ill risk a higher profile...
Old Nov 22, 2009 | 02:13 AM
howsoonisnow1985
If you got an R56, no risk the 225/40-18
conky
Apr 6, 2016 08:03 PM
madmax88
Oct 26, 2015 01:45 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Chippawaguy
Travel Stories
Aug 18, 2015 04:34 PM
jerjer
Tires, Wheels, & Brakes
Mar 27, 2007 09:59 AM
