Just replaced thermostat / housing - Rough idle?
Old Nov 14, 2009 | 04:12 PM
PirateMini's Avatar
PirateMini
Howdy folks, had to replace my thermostat. Haven't dug into the R53 since I owned it so this is all new to me.
Pulled the airbox, ecu, intercooler and thermostat - replaced the thermostat, airbox, ecu and intercooler. Easy right? Well - the coolant leak is fixed, but he car is idling higher than normal and the car is 'lunging'. My gut tells me that I either swapped something on the MAF or something on the air intake side.
Any one want to take a guess? Throwing an SES code. Will run it tomorrow and figure it out.
Old Nov 15, 2009 | 05:29 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Does the exhaust sound little different too ?
1) Make sure the couplers and clamps for the intercooler are on properly......sounds like you have a vac leak via the IC.
2) Double check the ECU cables you removed and make sure they are pressed and locked in properly.
Old Nov 15, 2009 | 06:39 AM
PirateMini's Avatar
PirateMini
Thanks - yes, the exhaust did sound strange. I will check that first.
Really appreciate the help.
Old Nov 15, 2009 | 07:32 AM
-=gRaY rAvEn=-
Moderator
np. The rubber couplers esp aftermarket ones are designed to be on there really snug so they have a tendency not to slide on properly on the undersides where you can't see. When this happens the vac leak gives you deeper exhaust note sorta like a MINI sherman tank, and you experience power loss/lag....
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
scottrn
Aug 22, 2015 07:26 PM
PSIChocolate
Aug 13, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
