R56 Engine mount crack?
Old Nov 12, 2009 | 02:17 PM
SouthSeaSadie's Avatar
SouthSeaSadie
Engine mount crack?
I just got a report from a free (dealership) check up on my MC 2002, and was told I have a front motor mount crack? Yikes! Is this as serious as it sounds and how could it have happened when the car has never been in an accident? 34,500 miles. Also lower control arm bushings cracked.
I just had the whole front bumper area replaced for cosmetic reasons. Shouldn't they have seen this?
Old Nov 12, 2009 | 02:46 PM
Robin Casady's Avatar
Robin Casady
Did you mean to post this in the 1st Gen forum? This is 2nd Gen.
Old Nov 12, 2009 | 03:47 PM
tazio's Avatar
tazio
1st Gen rules!
SSS - Don't worry. Motor mounts are very cheap to replace.
Old Nov 14, 2009 | 12:21 PM
sequence's Avatar
sequence
You dont need an accident to have this happen. Cracked (and leaking) motor mounts were an issue with first gen cars; I went thru two of them with my 05 S in barely 27K miles. That and a mulitude of other annoying and expensive (for bmw to fix) problems.
First gen cars rule? Not from my perspective, Taz-bro.
Old Nov 14, 2009 | 01:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This is common. As the early motor mounts get old they get shorter and when that happens they put extra stress on the upper mount on the strut tower and crack it. So you need to replace both to do it right.
As for control arm bushings, they are known for going bad all the time.
Replace them with the Powerflex bushings and your problem will be gone.
Old Nov 14, 2009 | 05:16 PM
tazio's Avatar
tazio
I just meant that the 1st Gen is a superior driver's car.
Old Nov 14, 2009 | 05:21 PM
tazio's Avatar
tazio
I'm about ready for another set of CA bushings. Way, how does NVH with the Powerflex bushings compare to the stockers?
silence2-38554
Nov 12, 2015 09:39 AM
StuRat
Aug 24, 2015 06:24 PM
PaulWalliDumali
Aug 21, 2015 04:46 PM
M7Speed
Aug 6, 2015 01:48 PM
