16x7.5 et20
Old Nov 10, 2009 | 09:53 PM
JohnnyVillan's Avatar
JohnnyVillan
16x7.5 et20
Anybody running wheels that size/offset? What size tires for a sexy stretch but not a ridiculous amount? Will I be safe driving daily or will I destro the axles?
RALLY!!
Old Nov 10, 2009 | 10:22 PM
IceManMCS's Avatar
IceManMCS
99% sure those would rub if you had any tire on the rim and were lowered.
Old Nov 11, 2009 | 08:03 AM
JohnnyVillan
Where would they be rubbing? Is the offset the problem?
Old Nov 11, 2009 | 08:38 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
The poke wouldn't be so bad if the wheels were wider so you could run a bit of stretch. Low offset is hard to pull off on skinny wheels. I'd go with higher offsets or wider wheels.
Old Nov 11, 2009 | 08:41 AM
Creeve's Avatar
Creeve
That wheel will poke around an inch. The main problem will be getting a tire to stretch enough to allow for that poke. Going to have to run something like a 195/40 or smaller.
Ahh, I got beat
Old Nov 11, 2009 | 09:04 AM
JohnnyVillan
So if I go wider will I still have rubbing issues? Whats a good width for 16s then?
Old Nov 11, 2009 | 09:36 AM
Rally@StanceDesign
Depends on the offset. "Good width" depends on the owner and application. People have fit anything from 5.5 up to 9 inches wide.
Old Nov 11, 2009 | 09:39 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Ahh, I got beat
If 195/40-16 then very few tires to choose from.
Yokohama S.Drive
It's not an ideal tire for the MINI
Load rating is too low at 80, usually need 84 or higher
Tire diameter is too short at 22.1", stock is 24.3"
Fits rims 6.5-7.5" so you could stretch it on an 8" rim for effect.
195/45-16 might work better.
Michelin Pilot Exalto PE2
Yokohama S.Drive
Old Nov 11, 2009 | 10:01 AM
Rally@StanceDesign
195 will stretch an alright amount on 7.5's. It's not much, but it'd be enough to offer some clearance.
Old Sep 17, 2010 | 07:13 AM
gokaht's Avatar
gokaht
Looking at this myself - set of Kt1's in 16x7.5 - 2 @ ET35, 2 @ et 20 :(
I was told by the seller to try 205/45r16 tires...
Old Sep 17, 2010 | 09:25 AM
lumpy's Avatar
lumpy
Yep, they are my wheels.
205/45/r16 Falken 512s specifically. According to Rally and other gurus you need to run a tire that will stretch a bit. A 205/45/16 Falken 512 will actually give you more room than 195/45/16s like the S-Drives.
Rally officially hates me...
Tata Steva
Sep 25, 2013 04:26 AM
WRXTURBO
Tires, Wheels, & Brakes
Oct 28, 2012 12:15 AM
Pocket-rocket
Oct 12, 2006 06:38 PM
Alex@tirerack
Oct 4, 2002 02:26 PM
