R56 215 50 17 snow tires - quick question
Old Nov 9, 2009 | 10:16 AM
mkortering5's Avatar
mkortering5
anyone running 215 50 on their stock 17s? I really want a little more ground clearance and this might be a good way to get that. let me know your thoughts.
Old Nov 10, 2009 | 07:16 AM
sequence's Avatar
sequence
depends on what kind of snow driving you're doing-- 215s are too wide for effective snow traction, and 50 doesnt seem tall enough to get you thru the deep stuff.
For snows, I'd rec something on the order of 185-190 and about a 60-70 in height at minimum--the narrower and taller, the better. Why not find a set of 16 rims that will clear your brake calipers (say the OEM Bridgespokes) and stick on a set of 185/70s? Sure yr MINI might look funky, but that will certainly help with clearance issues when plowing thru snow, and 16" rims will aloow you to run taller snow tires. That's the key: narrow and tall.
Old Nov 10, 2009 | 08:50 AM
NightFlyR's Avatar
NightFlyR
+1
I agree with this, narrower is always better in the snow
Old Nov 11, 2009 | 05:07 AM
GP0256's Avatar
GP0256
absolutely true, narrower actually cuts through snow better than wide tires believe it or not. In snow, more surface area=less traction.
Originally Posted by JRoca
+1
Old Nov 11, 2009 | 06:16 AM
iwashmycar's Avatar
iwashmycar
yeah your best bet with 17s probably wouldnt be to get giant balloon tires. same with the 16s. a 60 or 70 is incredibly tall.
granted i got 205/55/16 for winter, which are both wide and tall, a 60 or 70 would not even fit the wheels wells lowered.
maybe a 195/50 on the 17s? dont want to go too narrow ans just be stretched on there
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
col127
Aug 21, 2015 02:11 PM
PhoenixR61
Aug 21, 2015 07:40 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
