Check engine light on after closing hood
Old Nov 5, 2009 | 02:10 PM
Peartree's Avatar
Peartree
Every time I close the hood on my '05 convertible the check engine light comes on. It clears by itself after driving for a while. Any thoughts on what connector is loose? This also happens occasionally when I wash it.
Old Nov 7, 2009 | 05:30 AM
thecigarman's Avatar
thecigarman
I believe that the hood openings and closings are monitored as part of the adjustment of the service interval.
The first thing I would look at is the switch/sensor in the bonnet hinge. I bet it is bad, particularly if this also happens when the car is washed.
The light clears because it is no longer getting the fault. You might try putting a code reader on after you open and close the hood and before you drive. There may be a fault code. You have to read it before it clears.
Good luck chasing electrical gremlins...
Old Nov 7, 2009 | 06:04 AM
cristo's Avatar
cristo
Alliance Member
I thought codes remain even if the light clears. I know this is the case on my wife's 2001 VW.
Old Nov 8, 2009 | 06:03 AM
stevecars60's Avatar
stevecars60
This is true.
Possibility #1 - There is a wire harness that crosses the radiator shroud right under the rubber seal. Look to see wheather the connector on the T-MAP harness has any rub damage ( it's the sensor on the front of the intake manifold ).
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
