Losing Daylight? Light up the night with these specials!
Old Oct 28, 2009 | 10:43 AM
Mini Mania's Avatar
DAYLIGHT SAVINGS! - HALOGEN COPILOT MAP LIGHT
If you have a 'co-pilot', navigator or just friend trying to help you find your way at night then this 12 volt halogen light is the right answer. Plugs into the cigarette lighter outlet; its flexible neck allows you to aim the light where you need it and not into the driver's eyes.
On Sale! $27.95
part no: NMI6001
DAYLIGHT SAVINGS! - HELLA 500 DRIVING LIGHTS PAIR - MINI COOPER AND S
Rugged construction for performance and durability. Provides excellent visibility on and off-road. High impact black ABS housing, aluminum vapor-coated reflector. Upright mounting via single stud. Sold in Pairs. As the premier auxiliary auto lighting company in the world, Hella crafts the 500 Driving Light for outstanding performance and long life. All the parts you need for an awesome setup are included in the Hella 500 Kit: 2 lamps with H3 bulbs, 2 stone shields, a color-coded wiring harness, a fused 12v relay, an illuminated in-cab rocker switch and all necessary mounting hardware.
On Sale! $99.95
part no: NMA3027
DAYLIGHT SAVINGS! - DRIVING LIGHT KIT - MINI COOPER AND S
These auxillary driving lights on a MINI Cooper will provide great looks not just from the ourside in but more importantly from the drivers point of view. Quality drving light can make you a safer driver and help you avoid the blind spots. Dark country roads can be a real problem when you are driving a small sports car and these lights will minimize the potential problems of speed. Our special kit includes 55W bulbs mounted in high quality chrome housing, mounting brackets for the MINI Cooper and MINI Cooper S and a wiring harness. Fits 2002-2006 R50 MINI Cooper and R53 Cooper S, and 200
On Sale! $249.95
part no: NMK8000
DAYLIGHT SAVINGS! - DRIVING - RALLY LIGHTS CHROME PAIR - MINI COOPER AND S
For your 2007+ R56 MINI Cooper and Cooper S Hardtops, and the 2008+ R55 MINI Cooper and Cooper S CLUBMAN. You don’t have to compete in rally racing to outfit your MINI like one. These sporty driving lights will brighten the way on the darkest night. They work with the standard high beams and have a separate on/off switch for use at your discretion. Requires Driving lights, Grille with Mounting Bracket, AND Switch. Order this: G2NMA1031 - Driving Lights Black AND One of the following: G2NMA1032 - Grille with Mounting Bracket Mini Cooper G2NMA1033 - Grille with Mounting Bracket M
On Sale! $329.95
part no: G2NMA1030
DAYLIGHT SAVINGS! - PIAA 540 XTREME WHITE DRIVING LIGHT KIT,
02-06 MODELS
Factory style driving lights, but better and less expensive! This special kit from PIAA is a direct replacement for the factory kit while providing better lights and better visibility. Kit includes a pair of black 540 Xtreme white driving lights, two mounting brackets, wiring harness, relay, switch and mounting hardware. The lights and lens are 5" diameter, with removable stone guards included. (Both the MINI and PIAA lights have an 'outside' case diameter of 5 inches. However the lens (glass) on the MINI driving lights is 4 inches, while the PIAA is 5". "The better to see you with my dear!")
On Sale! $329.95
part no: NMA3022
danielbrookes_9
Oct 3, 2015 12:51 PM
TrueEddie
General Discussion
Aug 24, 2015 09:31 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
nismo4life
Aug 5, 2015 08:31 AM
