Interior/Exterior FULL blackout for $7.28
Old Oct 14, 2009 | 09:28 PM
epanarese's Avatar
epanarese
I just finished reinstalling all my blacked out parts on my 03 BRG/B MCS. Full blackout for a whopping $7.28. The 'recession blackout'. This includes:
-Gas cap
-Trunk handle
-Emblems
-Beltline
-Headlight rings
-Side markers
-Grille surrounds
-Grille (wait for it...with electrical tape)
-Tints (came with the car)
Pics and writeup tomorrow AM
Old Oct 14, 2009 | 09:35 PM
schreiber117's Avatar
schreiber117
subscribed
Old Oct 14, 2009 | 11:48 PM
GumbyLara's Avatar
GumbyLara
You have my attention...
Old Oct 15, 2009 | 12:10 AM
Oxybluecoop's Avatar
Oxybluecoop
Old Oct 15, 2009 | 12:20 AM
GumbyLara's Avatar
GumbyLara
Lol! That's exactly what I was thinking because that's what I did. Plastic-dip and electrical tape!
Old Oct 15, 2009 | 05:15 AM
ImagoX's Avatar
ImagoX
What will it look like in 6 months, though?
I used satin vinyl (the kind used in sign making) to black out my grille and beltline trim, and it's lasted years. Eventually it will need to be replaced, but sign vinyl (available online or at any local sign shop) is made to endure sunlight and heat/cold outside.
Someone local to me used PLastidip to do his headlight rings and other bits, but he didn't even want us to touch it with a fingertip because he was scared it would chip. Me, I'm to lazy to re-do the job every few weeks (or even every few months) to even out the color - I'd rather spend a little more and not have to redo it for 2-3 years. Can't argue with the price though, that's for sure.
Old Oct 15, 2009 | 05:26 AM
iwashmycar's Avatar
iwashmycar
PlastiDip is a tank lol
I did my grille surrounds at one point.... You can pretty much wash it normally and everything...wont come off. Had mine dont for about 8 months...then just decided to peel it off one day. Came right off.
Went to body colored vinyl now
Old Oct 15, 2009 | 05:33 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep - plasti-dip is PLENTY durable when done right - texture and color are perfect.
Old Oct 15, 2009 | 05:51 AM
ImagoX's Avatar
ImagoX
Do you need to do any prep work to get it to endure? I have to do AMy's new car's grille - I was about to order the vinyl for the project but I might just try this....
Old Oct 15, 2009 | 05:59 AM
iwashmycar's Avatar
iwashmycar
no prep...just clean. Also like on a grille surround i put big nails in some foam board to set them on....you dont want it "glueing" itself to wherever your painting....because when you go to lift it up itll peel by being stuck to the surface
i also used coats...just like regular paint. if you mess up dont worry...just peel and redo
Old Oct 15, 2009 | 06:18 AM
ImagoX's Avatar
ImagoX
You did the slats AND the surround or just the surround? Do you have pics of how it came out? Thanks!
Old Oct 15, 2009 | 06:58 AM
iwashmycar's Avatar
iwashmycar
noo just the surround
i wouldnt even hesitate to do rims with it...long as you already have the tires on obviously
Old Oct 16, 2009 | 08:19 AM
schreiber117
So will the op ever chime in here?
Old Oct 19, 2009 | 04:06 PM
epanarese's Avatar
epanarese
Sorry for the delay everyone. Been very busy with work. Anyway, here it is. I decided to keep my badges silver, because they aren't the ugly 'chrome' color I hate. I also didn't get around to the door handle yet. So the list so far is:
Beltline
Gas cap
Rear hatch handle
Headlight rings
Grill surrounds
Grill (stock grill)
Side marker vents
Tints (came on the car)
Tell me what you think.
Old Oct 19, 2009 | 04:30 PM
schreiber117
so was it plastidip?
Old Oct 19, 2009 | 04:32 PM
cmcveay's Avatar
cmcveay
Can't argue with any of it as my blackout project will run just about the same. I've got a roll of 3M super 88 tape and a roll of Super 33+ tape on my desk waiting for another club member to come over on Wednesday and we are going to knock out the beltline on his. I like the Super 88 as it's nearly 2x the thickness of the Super 33 and the semi-gloss finish looks awesome.
If the surface is clean and you allow it to "wrap" around the edge/corner of the object, Plasti-dip is indeed durable. I've run my grill surround and headlight rings through the car wash (self wash with the power washer) several times with no problem. No, I don't get the spray nozzle right down onto it as I am sure it'll give up and peel off. I have no problems with it being touched though. Be careful of taping areas off as the junction between the masked off area and the painted area will dry to become one. When you pull the tape off, you'll probably pull off all of the work you just did.
Enjoy, it's a pretty easy project and the results are very much worth it.
Old Oct 19, 2009 | 04:42 PM
epanarese's Avatar
epanarese
Combination of plastidip and electrical tape.
Plastidipped everything but the beltline and the grille (grille surrounds were plastidip though)
Old Oct 19, 2009 | 09:11 PM
MrCooperS's Avatar
MrCooperS
Moderator
Looks great. Did you buy the tow hook front mounted license plate holder? Or home made?
Old Oct 19, 2009 | 09:20 PM
epanarese's Avatar
epanarese
Home made with 2 screws haha
Old Oct 19, 2009 | 10:27 PM
mattsenpai's Avatar
mattsenpai
is plastidipping as difficult as it seems?
Old Oct 20, 2009 | 05:16 AM
iwashmycar's Avatar
iwashmycar
no easier than regular spray paint in my opinion
Old Oct 20, 2009 | 05:59 AM
thulchatt's Avatar
thulchatt
Not difficult at all.
Clean the part and put several lite coats on. That is about it. Any mistakes are easy to cover/correct with more layers. Worst case you peel the stuff off and start over.
Old Oct 20, 2009 | 04:01 PM
MrCooperS's Avatar
MrCooperS
Moderator
It's attached to the bumper?
Old Oct 20, 2009 | 04:28 PM
cmcveay's Avatar
cmcveay
Blackout project
Here's my blackout project that's nearly complete. Tape on the Beltliine, Plasti-Dip on the grill surround/grill, headlight ring and side scuttles. AC's molded MINI badge cover (opted for no decal on it) and the Joey Mod using flat black Hi Temp exhaust paint to minimize the chance of bubbling.
The only thing I have left to do is get the door handle covers, gas cap cover and rear tail light surrounds and the project will be done. I opted for the AC covers on the rest of it for better durability.
For those worried about the durability of the Plasti-Dip, I used the buffer on the car today and I intentionally got it over on the headlight rings and the grill surround with the cleaner. No harm at all. When I was done, I went over all of the tape and PD parts with a good vinyl protectant and it looked great.
Now I have to wonder if black viper strips would be over kill?
Ya gotta love these things!
Old Oct 20, 2009 | 04:39 PM
epanarese's Avatar
epanarese
Previous owner already had 2 holes there. Beats covering up your radiator.
