R56 brake pad sensor
Old Oct 10, 2009 | 05:33 PM
jacksonrw's Avatar
jacksonrw
brake pad sensor
I just changed my front and rear pads
i hate those broken sensores for pad wear
so I spliced the wires together
now the abs light and and a couple of other warning lights are on.....
thoughts
please help
Old Oct 10, 2009 | 08:46 PM
e30r56's Avatar
e30r56
Thoughts? You did it wrong. You should have replaced the broken sensors with new unbroken ones. The computer doesn't like the wires spliced together. Or something just needs to be reset. Or you broke something else.
Old Oct 10, 2009 | 09:29 PM
jacksonrw's Avatar
jacksonrw
yep I think i did something wrong....
so
I will buy new sensors and installthem
I couldnt have damaged anything else
i tested what I was doing
when i snipped off the damaged sensors brake pad light remained on
when I wired them together allhellbroke loose onn the dummy lights
I will sepearate wires to see if I can tract a step back
and then order new sensors
any other ideas?
Old Oct 10, 2009 | 10:01 PM
Oxybluecoop's Avatar
Oxybluecoop
Disconnect the negative battery terminal. Press the brake once and let it sit for an hour. Follow the brake pad service light reset procedure. Done.
-Chad
Old Oct 10, 2009 | 10:48 PM
nkosi1968's Avatar
nkosi1968
I hope you did not mistake the blue sensor connector (ABS Sensor) for the black/white (Brake Sensor) connector? I made that mistake and my ABS lights also came on.
HaveATank
Sep 4, 2015 08:04 AM
Aug 25, 2015 09:18 AM
HaveATank
Aug 24, 2015 10:26 AM
