How to put rear up on jack stands with OEM jack
I just want to get the rear of the car up on jack stands so I can do the rear brakes.
I've read the posts about using a real floor jack with a 2x4 on the side of the car to jack it up and put jack stands under, but I don't have a floor jack.
Is it possible to get the rear up on jack stands using the OEM jack? How?
If you are investing in the tools to do your brakes yourself a jack is a wize investment.
If you have a HF nearby be sure to get the brake piston compression tool while you are there!
What coupon???
Most auto magazines have Harbor Freight coupons and you can print this one:
http://www.harborfreightusa.com/usa/...0&keycode=0000
I was able to go to sears, and get a floor jack and a pair of jack stands for around 50-60 dollars. Do it, it is totally worth it, the jack I have isnt big enough to do SUV or anything but it is perfect for normal sized cars.
Don't try to do it with the OEM jack. I did and the car nearly fell off. Worse, the jack damaged the slot where the head is supposed to lift the car!
I don't get it. I wouldn't be surprised if they didn't even test the design properly. Makes no sense at all. Why didn't they use the design for the BMW 7-series? If you watch the movie "Transporter," you'll see how it works. Take a cover off the side of the car just under the passenger side door and the jack goes in the hole. You'll have it off the ground in ten seconds.
minipopkart
Aug 13, 2015 05:22 AM
