Interior/Exterior Beltline trim: outmotoring vs. vinylstyles
u know.. I did mines with ELECTRICAL tape (the one that could withstand heat), and it's wide enough, so u dont have to trim it. and it looks BAD ***
and still has not come off and matches the black rubb er parts perfectly.
however, you'll have to leave extra slack at the ends cus it does shrink about 1 cm on each side. ...
and still has not come off and matches the black rubb er parts perfectly. however, you'll have to leave extra slack at the ends cus it does shrink about 1 cm on each side. ...
Just go out and buy a roll of 3M indoor/outdoor eletrical tape. It's around $5 a roll, and a roll has enough to do at least 3 or 4 cars. I matches perfectly and is pretty stretchy so it makes going around the tight corners a breeze. I did mine 3 weeks ago and I've had no problems so far except one corner came up where I didn't dry it good enough, but that was a quick fix.
