R56 The Rattle of Death...
Because I heard a nasty metallic rattle yesterday. Since I bought the car used from a private party, and have done some simple mods, CAI, suspension, Strut brace, and exhaust, I'm preparing myself for Mini San Francisco do say that my waranty is void and they wont cover the replacement. My M3 mechanic has been working on my cars for years, so he would be the guy to eventually do the job. I wanted to get an idea on cost out of waranty.
I visited realoem.com and checked out the cost of parts which came out to be roughly 800.00. Then I saw some where that the amount of hours it take to replace 10-12, I assume labor is going to be around 1200.00. So I guess a rough estimate for a complete replacement will be a bit over 2000.00 taxes included.
Does this sound about right?
Since the only engine mod is the CAI, and the timing chain tensioner is a known issue, you may still be covered. The warranty does not die when a MINI is sold. Even if it was out of warranty, you may find them willing to do it without charge. If not, I would argue that the cause is a known design flaw that has been corrected by a redesigned part. MINI should cover it, whether it is discovered under warranty, or not.
If all they do is change the tensioner, it's about an hour IIRC.
But changing the timing chain, all the slides, the tensioner and sprockets requires disassembling the front of the motor - it's a real job......
If it actually fails while in service, you could be looking at a lot higher costs. My friend's '07 camchain tensioner bolts broke off at highway speed and caused lots of damage. The dealer installed a new shortblock engine assembly under warranty.
The way I see it is, if they are not going to honor the waranty, then I'll just pay for the diagnostics and then have them put it back together and take it to my BMW guy. He's a lot less than the dealer, and a great BMW mechanic.
Vince
Vince
A search for "cold start rattle" on NAM would show it to be exclusive to the MCS.
While it is possible that the cam-chain tensioner may have been changed for the MC as well,
you're not going to get a warranty replacement without showing the problem.
I'm not clear on this. I have a 2009 MCSa which has had the cold start rattle once (when I started the cold engine to move the car a few feet and then turned it off...which I've made certain never to do again).
Do I need to demonstrate the problem at the dealer or is this such a clearcut issue that they'll measure the timing chain deflection and repair/replace the tensioner without question?
Only your cold air intake mod involved the engine. Take if off before going to the dealer about the timing chain noise. Then there is no reason for them to deny warranty coverage of the timing chain tensioner if it requires repair or replacement. If the dealer causes problems, take your complaint to the next level by contacting the manufacturers zone representative. These are the best technicians who handle issues too tough for the local dealer. I do not know if Mini has this system, but it is used by many other vehicle manufacturers. There will be contact information in your warranty booklet.
Dropped off my mini today. So far everything been positive. Told them about the simple mods and they didn't seem to concerned about it. They are keeping it over the weekend since they couldn't reproduce it today.
v
v
