R55 Sirius Antenna Installation
Old Sep 22, 2009 | 01:44 PM
Wilkie's Avatar
Wilkie
Have a 2009 Clubman. Has anyone installed the Sirius Antenna in the existing Antenna Pod on the roof? Does the wiring for the Sirius Antenna exist? Instructions?
Old Sep 22, 2009 | 01:55 PM
BMW13's Avatar
BMW13
Do a search, apparently you can hook an XM or Sirius to the car antenna underneath the passenger seat in the front. You need a special connection you can purchase only through 1-2 companies. I'm going to hook up my XM this way when it arrives.
Old Sep 23, 2009 | 01:39 PM
schatzy62's Avatar
schatzy62
The SAT antenna is already in the car and wired to the space under the passenger seat. if you are adding an aftermarket SAT receiver then you can get a cable to extend this to where ever you want to put it.
Search the NAV and Audio section and you will find what you need.
Old Sep 23, 2009 | 03:51 PM
TRL's Avatar
TRL
This is the correct cable. Connects to purple wire under passenger seat. Works with my Sirius perfectly.
http://www.cdint.com/catalog/model/SB9SBJ-174-5
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 7, 2015 05:56 AM
