$50 off Cold Air Intake
For NAM members only- Save $50 on our Cold Air Intake!
Improved airflow into the supercharger = more horsepower = better performance! The ULTRIK Cooper 'S' Cold Air Intake System improves on existing designs for greater efficiency. The stainless steel airbox uses a wider design with chamfered base to enable better airflow across the entire filter wile providing adequate clearance from other engine compartment devices. The high pressure area at the base of the windshield directs outside air into the airbox through the existing bulkhead opening.
The shape of the airbox frame in conjunction with its bulb type rubber seal provides a positive seal against the underside of the bonnet, eliminating the need for an obtrusive top.
THIS WEEK-END ONLY offer Expires 09/20/09
Use this Discount Code when placing the order: NAM-CAI
chrisx18240
26
Mar 16, 2022 09:56 AM
