R56 Grabby Brakes
Grabby Brakes
The brakes on my Cooper (non-S) provide little braking until i depress the pedal to a certain point where the brakes grab and sling me in to my seat belt.
I was hoping this would pass after 21k miles, but it's not improving.
Is this a common problem among Coopers?
Is there a fix for this behavior?
My brakes used to grab right away. Took a feather touch to stop smoothly. Not sure why you have some pedal movement without braking. I'd ask the dealer about that.
Because of the copious amounts of brake dust produced by the factory pads, I switched to Carbotech 1521 Bobcat pads. The feel of the brakes is significantly improved; much easier to control. Also, almost no brake dust.
It has been my experience that the brakes MINI uses have a whole lot of initial bite. It takes a soft touch not to have them really grab.
I did not like that feel & replaced my brake pads with Hawk ceramics. Low dust & not as grabby, for me they are perfect.
After 20,800 miles on my "JustaCooper" I have no issued with the brakes what so ever, I just had the Front Pads replaced by the Dealer, I could tell they had been replaced by the feel, but don't any issues with having to stand on the brakes to get Molly to stop. The feel is very light and when I need to brake I brake, if I need to slow down light pressure is all that is needed to slow the car down.
I would concur with other's who have said to have the Dealer take a look.
What does your OBC say about your Front/Rear Brakes needing service??!!
It is difficult to perform a 'limo-stop'; meaning a gradual release of braking at end of stop, so the suspension returns to level at a smooth rate.
Don't know if this is due to 'brake-grab' or is characteristic of the suspension.
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
