R50/53 High coolant temperature when on idle
Old Sep 15, 2009 | 04:23 PM
lsh321's Avatar
lsh321
Hello All!
I own Mini Cooper S 2006 convertable, automatic. A few weeks ago I started to notice a weird problem: after stopping on a traffic light (idle at 800RPM) the engine temp goes to the red zone very quickly. I hear the fun going on. If I put the transmission on neutral and get RPMs to 3,000 (still waiting on the traffic light) then the temperature quickly goes back to normal. Also, it goes back to normal as soon as I start driving.
I've spoke to a couple mechanincs already but they didn't have any good ideas. I read on the forum that it can be related to termostat but I am not sure how it explains the fact that the temperature goes back to normal when I go to high RPMs.
Thank you in advance!
Old Sep 15, 2009 | 06:36 PM
ron-s mini's Avatar
ron-s mini
Did you mean: High coolant/water temperature?
Unless you have added a aftermarket gauge you do not have an oil temperature gauge.
Old Sep 15, 2009 | 06:43 PM
lsh321's Avatar
lsh321
Right, coolant/water temperature. Sorry, just a typo.
Old Sep 15, 2009 | 09:19 PM
Dr Obnxs's Avatar
Dr Obnxs
Hmmmm
if the thermostat isn't opening all the way, then the low pump speed along with the partially closed t-stat can cause this. Also check that the cooling system is well bled, air in our cooling systems is a real pain.
Does your supercharger rattle?
Matt
Old Sep 15, 2009 | 09:25 PM
lsh321's Avatar
lsh321
Thanks! This is a good explanation about low pump speed + partially closed thermostat. Is there a way to determine if it is just a broken pump or broken t-stat?
Yes, the system is well bled, the first thing I did after noticing the problem.
It is hard to say about rattle. I think the sound didn't change.
Old Sep 15, 2009 | 09:35 PM
Dr Obnxs's Avatar
Dr Obnxs
In my experience...
the pumps are pretty solid. If it does start to go south, it will seep coolant and the level in the resevoir will start to drop. I haven't seen any impellors that have worn away. The pump drive on the back of the SC is known to go south, but if it's really shot, you get a lot of noise from the back of the supercharger, and you overheat at pretty much any rev...
Thermostats fail more often, and is a good place to start....
Matt
Old Sep 15, 2009 | 10:20 PM
lsh321's Avatar
lsh321
Thanks!
Old Sep 16, 2009 | 07:35 AM
Bigshot's Avatar
Bigshot
Would a low speed fan resistor failure cause this?
Old Sep 16, 2009 | 08:48 AM
lsh321's Avatar
lsh321
Well, I hear fun on low speed and then on high speed. And I don't think it explains the high-RPM "solution".
Old Sep 16, 2009 | 09:05 AM
Bigshot's Avatar
Bigshot
If the low speed fan wasn't working simply getting more water thru the radiator will lower temps as the radiator will bleed off some temp w/o moving.
Old Sep 16, 2009 | 01:39 PM
lsh321's Avatar
lsh321
Possible, will be checking all of that over weekend
Old Sep 16, 2009 | 04:12 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I changed the thread title to reflect this.
Old Sep 21, 2009 | 08:55 AM
lsh321's Avatar
lsh321
Just to close the thread: it was t-stat. Replaced it on Sat and had extensively test-drived the car on Sun without any problems.
Thanks everyone!
Old Sep 21, 2009 | 01:30 PM
Dr Obnxs's Avatar
Dr Obnxs
Cool!
Good it all worked out.
Thanks for letting us all know.
Matt
Old Sep 29, 2009 | 04:53 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Thanks everyone!
Did you flush and refill the system with the T stat replace ?
Did you test the thermostat on the stove or just assuming now that was it ?
Dont think this is case closed until you have tested the T-stat. Just flushing and refilling and re-bleeding the system may have indeed been the cure.
Old Oct 1, 2009 | 06:42 AM
broadwayline's Avatar
broadwayline
You need to go to better mechanics..... this is a simple thermostat problem, probably one of the simplest and most common cooling system problems.
Edit: I see the problem is fixed.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
