R50/53 03 MCS passenger power window failure
Old Sep 13, 2009 | 12:40 PM
b0bbY's Avatar
b0bbY
it just stopped working...seems the motor froze. anyone know if this is a full assembly that needs to be bought or can u get just the motor. when i hit the switch i here it click...so it has power. but nothing...it's also not dropping that half inch when the door is opened. so im guessing the motor locked. anyone had this issue? car has 28k mi. im in philly area...i looked online for a replacement but im guessing ill have to buy it from mini. was curious if anyone has done the install. doesnt look terriblly difficult...ive done power window motors/assemblies before. just looking for a lil help and or insight. thanks in advance...
Old Sep 13, 2009 | 12:45 PM
JAB 67's Avatar
JAB 67
Did it on my 2004 two weeks ago. Part about $125 from dealer. It is possible to overhaul the motor (rather than replace it) and get more life out of it, but as removal and reinstallation is not something you want to be doing very often, I opted for a new part. Look for other threads on the DIY steps, like this: http://www.mini2.com/forum/faults-fi...ing-guide.html
Old Sep 13, 2009 | 01:24 PM
JAROBERTSON's Avatar
JAROBERTSON
My passenger window had the same problem. The motor is located between the two speakers. I hit the panel with my fist and the window operates fine now. Good luck.
Old Sep 13, 2009 | 01:42 PM
JAB 67's Avatar
JAB 67
Most would agree that thumping the panel between the speakers is a temporary fix; sooner or later, the motor will need attention.
Old Sep 13, 2009 | 04:13 PM
buzzsaw's Avatar
buzzsaw
Found this window fix writeup that may help.
Old Sep 16, 2009 | 03:43 PM
minimotoman's Avatar
minimotoman
been there
I have this problem from time to time and from time to time either side will do it as well on occasion one of the door locks wont unlock when you hit the button no matter how many times you hit it. I keep trying to lower the window when I get in the car or sometimes turn the car off and back on and it will come back as if nothing happen. Usually it will be good for a month before this temper tantrum shows back up. I just find it as an annoyance. I have had this problem for over a year and a half.
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
clintmeister
Aug 12, 2015 11:11 AM
USA-RET
Aug 6, 2015 09:22 PM
