Replacing MCS 04 Belt Tensioner
Old Sep 10, 2009 | 05:19 PM
Neufusion's Avatar
Neufusion
My car has a rattle which at first I thought was the supercharger going out, but using a long screwdriver as a stethoscope I found the most noise coming from the Belt Tensioner. If it is indeed a failing belt tensioner, is it best just to replace it with the exact same part?
I've read in other post that certain year MCS's had mulitple versions of the belt tensioner. I'm wondering if there are multiple versions available for my 04 MCS or if there is a better aftermarket part to use.
Old Sep 10, 2009 | 07:13 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
MINI may have updated the part number, but the design has not changed over the years. I keep brand new ones in stock at all times.
http://www.waymotorworks.com/product...8&cat=0&page=3
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Sep 10, 2009 | 07:27 PM
boyeeshotrod's Avatar
boyeeshotrod
i recently replace mine, i walked into nappa and they got the tensioner in like 3 days for $100!!! its the exact same tensioner on your car, i was doin a 15% pulley so i changed the tensioner since i could get to it, also since i had 126k on my car i changed the idler pulley too!
Old Sep 10, 2009 | 08:57 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Great idea with the Idler Pulley....
And may as well put in an Alta Tensioner stop too. they are only 20 dollars and worth every penny...
sevin
May 2, 2026 06:11 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
