R50/53 noise from strut tower
Old Sep 9, 2009 | 12:45 PM
silverstrip04's Avatar
silverstrip04
Hello all from a newbie~
I have 04 MC and looking for some help.
I hear squeaky noise (like rubber rubbing against metal) on the passenger side every time I turn the steering wheel whether car is moving or not, and it is coming from strut tower. I can even feel rubbing if I put my hand on top of the tower.
Has anyone experienced this? Any suggestion?
Lubrication might do it but looks like I have to remove the strut assembly to get to it(?) If so, is here anyone who can give me 'do-it-yourself' instruction on how to remove so I can get to the part that is rubbing?
Is it even possible for non-mechanic to do this? One of my friend suggested that I take it to mechanic because of the Spring which required special tool.
thanks in advance for all your inputs.
Old Sep 9, 2009 | 01:06 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Sounds like a worn out or failed upper strut mount.
Old Sep 9, 2009 | 03:30 PM
Bigshot's Avatar
Bigshot
Old Sep 9, 2009 | 03:48 PM
silverstrip04
upper strut mount? then I do have to take the whole assembly apart...
Is it something I can do myself or better take it to mechanic?
Could there be an instruction on how to do this that someone can point me to?
Thanks for all your help~
Old Sep 9, 2009 | 05:12 PM
BlimeyCabrio
It's the same procedure as changing springs - you remove the strut assembly and replace the upper mount:
https://www.northamericanmotoring.co...ll-how-to.html
I've done mine several times - it's not very hard, if you're mechanically inclined, have the right tools, and if everything cooperates.
Old Jan 2, 2014 | 09:46 AM
rockjohny's Avatar
rockjohny
Strut noise
So what was your outcome? Ever fix the noise?
Old Jan 2, 2014 | 01:09 PM
suntaepark's Avatar
suntaepark
you will need a tool to push the springs on the struts.
If you have a tool, it is very easy.
Old Jan 2, 2014 | 05:07 PM
noodlesandsam's Avatar
noodlesandsam
Thread revival from 2009?
Supertractor3
Apr 7, 2017 11:16 AM
M7Speed
Sep 4, 2015 10:47 AM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
