R50/53 Power Steering?
Old Sep 5, 2009 | 12:07 PM
bmwg84's Avatar
bmwg84
Power Steering?
When I turn on my car, the power steering will not come on. I have to restart, and then it will kick on.
Old Sep 21, 2009 | 04:37 PM
mataleao's Avatar
mataleao
It can be the power steering pump electrical motor. You can get it rebuilt for $200 at http://www.bba-reman.com/us/index.aspx.
Old Nov 4, 2009 | 05:28 PM
Miniriffic's Avatar
Miniriffic
My car just started doing this, too. I noticed that when I start out in the morning everything seems normal, but after about 45 minutes of driving it suddenly feels like I've got to manhandle the steering wheel. My drive to work is mostly in a straight line for about 45 miles while I'm on the expressway, so it's probably not that noticable then anyway. If it is just the electrical PS motor why is it intermittent? I'd think it would either work or not but not return to normal.
Old Nov 4, 2009 | 08:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Def sounds like you need a P/S pump. I don't recommend the rebuilt units, I've had to replace them.
Old Nov 4, 2009 | 08:49 PM
Aaron Evans's Avatar
Aaron Evans
Hey guys, have any of you ever removed the pump? and if so, how did you get it out?
Old Nov 4, 2009 | 08:57 PM
Aaron Evans
I'm replacing my pump in 02 cooper, but I could use some help with the removal. It looks so simple but I cant get to the bolts that are holding it in. Is there a special tool I need. Any feed back would be awesome.
Last edited by Aaron Evans; Nov 4, 2009 at 09:00 PM. Reason: just to make it sound better
Old Nov 5, 2009 | 07:01 AM
ZippyNH's Avatar
ZippyNH
The wireing harness near where the pump plugs in can chafe too...worth a look.
Old Nov 5, 2009 | 07:10 AM
Nachtsturm's Avatar
Nachtsturm
Very common the 06 S is in the shop right now. Hopefully getting fixed.
Old Nov 5, 2009 | 07:18 AM
Gil-galad's Avatar
Gil-galad
Try these references:
http://www.mini2.com/forum/3686894-post694.html
http://www.mini2.com/forum/first-gen...-pump-diy.html
Good luck!
Old Nov 5, 2009 | 08:01 AM
ZippyNH's Avatar
ZippyNH
I would also suggest you look at getting the OEM power steering fan duct kit....it will provide better airflow to your new ps pump, keeping it cooler and also protect/extend the life of you power steering fan. The duct is 80$ from moss.... I have one on my s, took 10 min to install.
Old Nov 5, 2009 | 05:36 PM
Miniriffic's Avatar
Miniriffic
Does it hurt anything to drive without the P/S pump working? It may be a week before I have time to get this fixed.
Thanks!
Old Nov 6, 2009 | 06:18 PM
Miniriffic's Avatar
Miniriffic
I went to Mini of The Woodlands in Texas today. It turns out my P/S pump has an electrical fault and the fan is fine. No leaks - the fluid level was actually slightly above the max level.
Quote was $908.32 ($771.29 for the pump and $165 for labor).
Since it takes about an hour of driving to lose the P/S right now I'm going to hold off and see what happens. It's a disappointment that an '05 MCS with just shy of 80K miles needs a power steering pump. I've had other cars with nearly double the miles that never had this kind of problem. I've been driving for 34 years and never had one of these go bad.
Old Nov 7, 2009 | 08:29 AM
Gil-galad's Avatar
Gil-galad
This is a well known and well publicized weakness in the 1st Gen MINIs. You should be glad you got 80K out of your pump -- many people experience a failure with less miles than that.
I'm actually thinking about a proactive replacement at 75K. I've heard of others doing this and being amazed at the reclamation of performance they didn't realized they'd lost.
Old Nov 7, 2009 | 07:08 PM
WayMotorWorks
Vendor
Thanks!
I don't like advising customers to run their MINI without the P/S pump working. Over the years we've seen several Engine bay fires and I worry that these fires are sometimes caused by the pump shorting out completely. Not trying to scare anyone, but I don't want to see a MINI die a firey death.
Old Nov 7, 2009 | 07:24 PM
ZippyNH's Avatar
ZippyNH
It would also suck to have an accident and have the cause be "defective equipment".
Old Nov 7, 2009 | 07:40 PM
ZippyNH's Avatar
ZippyNH
The newer style pumps like on the MINI , some BMWs and an ever increasing number of cars are an DC electric motor with brushes that wear out much like an generator/alternator....so now they have become a bit of a wear item, rather than a lifetime item like earlier pumps in exchange for the 1 to 2 % fuel savings these pumps are said to save when compared to the old beltdriven pumps that run all the time.
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
Suspension Products
Sep 2, 2015 10:32 AM
