Air Conditioning help
Old Sep 2, 2009 | 09:39 AM
Coonsmini's Avatar
Coonsmini
Hi all I have a 2003 and the AC is not working. I am out of warranty so maybe someone has a idea on something I missed . No cold air. The freon is good to pressure as per the specification. The control seems to work lever on full. The Ac clutch is working and the fans are coming on. So any clue. Please it is so hot.
Old Sep 2, 2009 | 06:43 PM
mini22's Avatar
mini22
Do you have any check engine lights on or your dsc light on and won't go off?
Old Sep 2, 2009 | 08:09 PM
Coonsmini's Avatar
Coonsmini
No no lights dsc is fine??
whats do you think?
Old Sep 2, 2009 | 08:14 PM
Rich.Wolfson's Avatar
Rich.Wolfson
If the compressor is going on then I would first put in a can of Freon. I found that most of the Minis I have dealt with were charged at the low end of the spec and can benefit from a "boost".
Hopefully it is nothing more than that as the compressor is an expensive part as is the condenser, dryer or evaporator.
You are sure the clutch is engaging? My 2003 AC clutch went at the height of the heat last month.
Rich
Rich
MiniDan
Sep 3, 2015 04:05 PM
Zettinger
Aug 25, 2015 04:04 PM
polotska
Aug 23, 2015 09:10 AM
Bennyboy
Aug 18, 2015 07:28 AM
