R55/56/57 Auto-Everything and Accessory Module Update
We've tested the prototype (ugly home built unit, way too large and soldered by hand).
Matt & Guenter, your FES Auto team.
www.fes-auto.com
- Auto Sport Mode tested and working!
- Aux accessory control tested and working! this is really cool! two quick taps on the button turn the accessory channel on or off. Since the DSC system takes slightly longer taps to trigger, the DSC system doesn't even toggle state! I was surprised how much I like this feature.... This feature alone would really complete a stealth radar detector installation, as just one example. You could also use it to arm water/meth injection or a nitrous kit.
- Power On LED sequece (there are three LEDs that indicate channel setting status). When the car is turned on, they light up in sequence, then all flash twice, I think.... Looks cool. Also gives you visual feedback so that you can test during installation to make sure everything is working right.
- We've selected pluggable wiring headers to connect the unit. There's a five wire header for the power, ground and three button channels, and a separate five wire header for accessories. Power, ground and enable for each of the three channels. If you don't want to use the accessory channels, just don't install the header for a much cleaner installation.
- We've done the full surface mount board layout and full componenet selection.
- The unit is firmware upgradeable. We can reprogram the unit in case new features or automotive modes are introduced in the future (like the eDiff stuff). This means the unit will never really become obsolete!
- DSC system timing and programming. I've only got a 08 Clubman, so we have to find a willing JCW/eDiff owner to help us close this last bit.
www.fes-auto.com
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
