R56 r56 and torque steer
Old Aug 27, 2009 | 02:47 PM
zoranb's Avatar
zoranb
Isnt it strange that there is no sign of torque steer on the steering wheel when making a fast start?
Why is that? I mean, when you try this in the Astra OPC or the new Ford Focus RS there is little movement in the steering wheel! But on my mini with the lsd, there is no movement! Is that right?
Old Aug 27, 2009 | 02:49 PM
CLAG's Avatar
CLAG
I can get torque steer
hit it harder
Old Aug 27, 2009 | 04:55 PM
kyounger's Avatar
kyounger
I get LOTS of torque steer when I hit it hard. Feels like the diff is "hunting".
Keith
2007 MCS, with lsd. (The car, not me)
Old Aug 27, 2009 | 06:27 PM
russgriz's Avatar
russgriz
Little to no TS here. I have the LSD as well.
08 MCS
Old Aug 27, 2009 | 07:40 PM
countryboyshane's Avatar
countryboyshane
I have LSD as well. Slamming it WOT in 2nd gear I'll get a tiny bit of torque steer. After that it's practically non-existent.
Old Aug 27, 2009 | 09:09 PM
Benibiker's Avatar
Benibiker
I felt it in my 07 with lsd and barely notice it in my current automatic unless I really his the gas.
Old Aug 27, 2009 | 11:29 PM
Robin Casady's Avatar
Robin Casady
I get significant amounts of torque steer/anti-torque steer oscillation with my LSD equipped MCSm when I punch it in 2nd.
Old Aug 27, 2009 | 11:55 PM
mattsenpai's Avatar
mattsenpai
I haven't punched it hard enough to experience the torque steer.
but
Have you guys ever took a right turn at an intersection a little faster/sharper than normal to get that go-kart feel, and as you swing into the left lane your MINI runs over one or two of those reflector-central markers in the road and the impact throws off your steering a bit? Scary feeling; but i love the adrenaline. Gotta be more careful
Old Aug 28, 2009 | 03:02 AM
zoranb's Avatar
zoranb
2nd huh? I wonder why Clarkson (TopGear) tests torque steering by using only 1st gear. I recall he did that in both the AstraOPC and the new FocusRS!
Old Aug 28, 2009 | 04:05 AM
malteseracer's Avatar
malteseracer
I get it in first, second and third when I really punch it, but I don't have LSD.
Old Aug 29, 2009 | 11:22 PM
vjaramillo's Avatar
vjaramillo
I always get it when I punch it. I have LSD also.
Old Aug 29, 2009 | 11:25 PM
wgrzanic's Avatar
wgrzanic
I get it in my S auto. I like it though. Makes it feel like a wild beast that needs to be tamed!!
Old Aug 29, 2009 | 11:32 PM
Robin Casady
I get it in first as well, may even get it in third. I just like gettin' it on in 2nd gear.
Drive in the hills, forget fear
Gettin' it on in second gear
-- Buffalo Springfield
Old Aug 30, 2009 | 05:36 AM
Ottoman_FD3S's Avatar
Ottoman_FD3S
yup plenty of torque steer here as well in my 07 S
i bought it used so I have no idea if it has LSD or not..
Old Aug 30, 2009 | 07:45 AM
Robin Casady
Does it pull one way, and then the other, like a drunken sailor? If so, it has LSD.
Old Aug 30, 2009 | 08:01 AM
investigator's Avatar
investigator
I have never experienced torque steer in my '07 MCS unless I have the steering wheel turned sharply left or right. I can take my hands off the wheel for a straight line acceleration run and no torque steer. I've got LSD and it is lowered about an inch. Some "experts" seem to think the lowering is why no straight line torque steer.
Old Aug 30, 2009 | 09:17 AM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Originally Posted by mattsenpai
but
Yep, and I've posted several times about it. Real sphincter pucker.
Got to remedy this, cause the right foot on my 6sp is not getting any lighter.
Old Aug 30, 2009 | 12:35 PM
zoranb's Avatar
zoranb
Ok but why doesnt the steering wheel turn (when punching into first gear) like Clarkson indicates in the Astra OPC and Focus RS?
Old Aug 30, 2009 | 06:20 PM
r56mini's Avatar
r56mini
+1
Old Aug 31, 2009 | 09:34 PM
accel's Avatar
accel
I believe what I have is not torque steer. It's MINI's steering is hunting when front suspension is unloaded and body leans left-right under heavy acceleration.
Old Sep 2, 2009 | 08:25 PM
phillipcoopersgates's Avatar
phillipcoopersgates
The point of a LSD is to eliminate torque steer so if u have one u wont get it, if you didnt then you will
Old Sep 2, 2009 | 09:03 PM
vjaramillo's Avatar
vjaramillo
I have it and I still get it.
Vince
Old Sep 3, 2009 | 05:21 AM
slinger688's Avatar
slinger688
This is not exactly correct. The R56 Mini, especially high torque models such as MCS or JCW with LSD, suffers from "anti-torque steer", very similar to torque steer. "Anti-torque steer" is a term used by motoring file and not my choice.
It is an abrupt engagement of the LSD during a turn upsetting the car's balance and making it push suddenly to the outside of the corner. It happens mostly in bumps. There is some info from UK and Europe about this issue. That is the reason why the 2009 Factory JCWs and the 2010 onward Minis no longer have the mechanical LSDs.
Old Sep 3, 2009 | 07:40 AM
Robin Casady
Nope, it is to minimize wheel spin and get more power to the road. The LSD has torque steer, followed by anti-torque steer, followed by torque steer, etc. This oscillation makes hard acceleration "interesting" but I'd rather not have it.
Old Sep 3, 2009 | 08:10 AM
accel's Avatar
accel
This must be specific to MINI OEM LSD.
'Cause I have Quaife at my other FWD car, and so far the way it works - it eliminates understeer big time. It's pretty straightforward - inner wheel has less traction in the turn, so it spins under acceleration. Torque sensing diff will transfer extra torque to the outside wheel making both wheels work the road and car's nose stay planted. Without LSD once inner front wheel spins - it has little or no lateral grip, and another wheel's grip is not enough - so the nose goes out, the car understeers.
If you accelerate strong enough to make both of your wheels spin - the outer wheel will push car's nose inside the turn pretty similar way to Honda's ATTS system.
But if you went into the turn too fast, then nothing helps - the car will follow it's natural handling attitude and LSD influence is minimal here.
Tested at autocross many times.
I haven't taken MINI there yet.
