Suspension Engine and trans bushings- PowerFlex or Ireland?
Old Aug 27, 2009 | 10:05 AM
Aeromax's Avatar
Aeromax
I've read around on the forum, and it seems that the ireland ones are harder to install and are a little less forgiving. Is that the general consensus? I'm trying to decide which ones to order.
Old Aug 27, 2009 | 10:19 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Not sure why a few guys have issues installing the IE parts when they fit in the same place and the same way. Our tech's installed both without issue.
Old Aug 27, 2009 | 10:33 AM
Aeromax's Avatar
Aeromax
Do you know if there is a difference in NVH? Seems that some people have lots, and some people have little to none.
Old Aug 27, 2009 | 06:48 PM
AutoXCooper.com
NVH is subjective at best, but there does seem to be less of it in the early motor mount setup. I'm not a fav of the lower mount on any MINI unless you are hardcore AutoX or Track guy, I just don't see the performance improvement for the cost of the extra NVH.
Old Aug 27, 2009 | 07:45 PM
Aeromax's Avatar
Aeromax
Well my engine definetly moves a bit. You'd recommend changing the top and trans mount first?
Old Aug 27, 2009 | 08:37 PM
KC Jr 54's Avatar
KC Jr 54
I have the Ireland lower and trans mount inserts and both were installed very easily. No grinding or anything of the sort when necessary. The NVH initially is quite high, but it has settled down quite a bit. Personally i like the feel.
Old Aug 27, 2009 | 08:49 PM
leapfrog's Avatar
leapfrog
Well I've had the TSW damper on top, but still seemed like there was engine rock. So a vendor suggested to first try the Powerflex lower engine mount, but only the large one. It was very east to install, and did eliminate most of the rock. However, a few thousand miles later, I've picked up a squeak and a rattle in the dash at different engine RPMs. Because of this, I decided not to put this setup on my my wifes '05 Cabrio S. It is developing it's own squeaks and rattles!
Old Aug 28, 2009 | 06:21 AM
AutoXCooper.com
Yes but you can aloways order all of them, install all of them and remove the lower one if the vibs are too much for you. The parts are not big dollars. If you don't have a TSW Damper Kit think about one of them too. Both parts can be found on my site.
Old Aug 28, 2009 | 06:25 AM
AutoXCooper.com
Think about the TSW Xbrace for the R52. Many R52 owners have reported to me that it helped with many of those squeaks and rattles also help in the corners too
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
