R50/53 When Replacing Battery...
Old Aug 18, 2009 | 01:52 PM
purplehaze05mcs's Avatar
purplehaze05mcs
Hi All,
Will I loose ecu programs like drl, window, etc when I disconnect the battery.
If so, will inserting that thingy with a 9-volt batt. in the cig lighter help keep the program? You know, that thingy that keeps the radio stations in memory.
Anybody know?
Old Aug 18, 2009 | 02:02 PM
not-so-rednwhitecooper
No, it is all programmed, cannot be erased with a battery disconnect.
The radio settings are saved ine the radio and will be unaffected by the battery disconnect. The clock, however will need reset. You will also lose your trip odometer readings.
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Knuckle14
Aug 26, 2015 08:10 PM
JPMontes3
Aug 23, 2015 01:26 AM
