Interior/Exterior Hot center counsel??
Old Aug 16, 2009 | 12:09 AM
chad1140's Avatar
chad1140
Who else has a Whalen shift machine on a Craven Short Shift Kit with metal cover, and high flow header and Cat with JCW exhaust. When it gets above 95 degrees out side the whalen get REAL warm and the craven metal cover to the shift well is easily 100 or so degrees. Is anyone here noticing this getting really hot to th point you make sure your car insurance is paid just in case it spontaneousley combusts. I need any one 's input so thanks in advance.
Old Aug 16, 2009 | 01:04 PM
AutoXCooper.com's Avatar
AutoXCooper.com
even with the stock header and cat my Whalen and Craven also get hot sitting in traffic on really hot days too. While not as hot as your's they get warm. I've thought about putting some type of insulation on top of the heat shield in such a way that doesn't cause issues with the shift box.
Old Aug 16, 2009 | 02:21 PM
chad1140's Avatar
chad1140
Yeah it has me concerned to say the least. I am gonna try to raise the adjustable shift lever from the craven shifter to see if that can put some distance between the heat source and in turn cool it down.
Old Aug 16, 2009 | 02:35 PM
ElPolloDiablo's Avatar
ElPolloDiablo
I noticed that the center gets pretty darned toasty after upgrading from stock to a RMW header. . .going to try header wrap and see if that helps.
Old Aug 17, 2009 | 07:25 AM
Professor's Avatar
Professor
I have noticed the exact same issue.
Let me know when you guys have a solution
Old Aug 22, 2009 | 09:53 PM
chad1140's Avatar
chad1140
To be candid with you guys I have never had so many issues from what is supposed to be a "street" header that If I run into one more wall from it I will trade it in. NON-stop codes that took $350 worth pseudo fixes and trial and error as well as wait for parts. Not a bad header for the track at all, but waaaay too many problems out of a street set up.
Old Aug 22, 2009 | 10:05 PM
batrugger's Avatar
batrugger
Funny, our race header has been issue free for almost two years
Old Aug 27, 2009 | 01:21 PM
Jeffsmashkot's Avatar
Jeffsmashkot
If you want to sell it, let me know...
Old Aug 27, 2009 | 01:38 PM
Jeffsmashkot
Back button ftl...
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
Aug 7, 2015 05:56 AM
